Results 1 to 7 of 7
Thread: Innovate and MAP.
Hybrid View
    Default Innovate and MAP.
    What is the best way to capture the MAP signal with the Innovate? I can't get to the MAP sensor. Is there a good alternative?
    Tony
    Can't you log MAP from the Scan Tool...?
    Sure can, but I was wanting a way to record the Map without having to have my laptop set up. Especially when I'm racing. I've tried using the black box logging but I've not been very consistant in getting it to work. I have my Innovate sitting on the consol and all I have do do is press the record button before a run down the track.
    I"m just hoping this will be easier for me. I'm assuming I could connect a wire to the PCM. The question is where?
    Tony
    Quote Originally Posted by tgeers
    Tony
    Tony,
    What BB problems have you been having...?
    When programming the BB with the PID's to log, you must be sure that the status line across the bottom of the Scan Tool window shows your correct VIN, OS, and transmission (manual/automatic); samething when pulling the logged data from the BB.
    I don't know enough about the LM-1, someone can add their comments here.
    Joe
    Jan 2005
    year make model of your car?
    I believe you will need a signal splitter of sorts if you want to log MAP in the LM-1.
    All said and done, it may very well be easier to troubleshoot your black box problems than to split the MAP signal.
    TA, you're up pretty late, eh mate...?
    Jan 2005
    Just getting ready to rig up the fuel pressure.
  1. the innovate LM-2
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2009, 02:22 AM
  2. Anyone using Innovate LC-1 WBO2s?
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2006, 02:50 PM
  3. Innovate LM-1 Voltages.
    By curtbriggs in forum General
    Last Post: September 4th, 2005, 03:15 PM
  4. Innovate LC-1
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 06:35 AM
