Results 1 to 4 of 4
Thread: Reading transducer data with a 411 PCM
    Mar 2007
    Default Reading transducer data with a 411 PCM
    I'm working on a 2000 Chevy S-10 that has a 411 PCM swapped in. The PCM is using a (2002 S-10) OS12212156. The stock 2002 does not have an EGR or a AC pressure sensor. I have never been able to read the EGR pintle voltage with the EFI scanner. The EGR is wired correctly. It appears as though the PCM is just not able to read this input. (Like it is disabled.)
    Is there a way to get the scanner to read the EGR signal (blueConn-pin55)?
    If the EGR won't work,.. Is there a way to read the transducer from the AC pressure sensor input? That is, is there a way to enable that line/operation for the 411 PCM? (What PCM pin does the AC pressure sensor go to?)
    Is there another way to read transducer data without doing some custom wiring?
    Thank you
    Do you have the EGR enabled in the tune?
    Mar 2007
    Quote Originally Posted by nonnieselman View Post
    I don't know.
    This sounds like what I am asking about. That is, I'm not aware this can be done, or where/how to do it.
    I will need to go looking for it.
    Post your tune
  1. 96 to 411 pcm
    By tokymon in forum Vortec V6/V8 Specific
    Last Post: December 22nd, 2018, 01:11 PM
  2. Data Log Reading Help
    By GhostC6 in forum General
    Last Post: September 2nd, 2017, 06:37 PM
  3. '96 4.3 to '411 4.3 PCM info...
    By joshwho? in forum Vortec V6/V8 Specific
    Last Post: October 14th, 2016, 10:43 PM
  4. Replies: 4
    Last Post: October 8th, 2013, 09:11 AM
  5. 411 PCM's
    By joecar in forum Lounge
    Last Post: June 4th, 2007, 11:07 AM
Tags for this Thread
