Results 1 to 3 of 3
Thread: Oscillating engine speed at low load
    May 2023
    Default Oscillating engine speed at low load
    Hi !
    I have a LQ9 engine with LS1B ECU. The engine has a BTR Stage 1 cam (223/230) and auto gearbox.
    The engine has gone through tuning with hub-dyno and runs fine. However, the rpm oscillating at low TP/RPM/load/speed.
    It occurs when drive at low speed (10-30 km/h) and low TP (11-13%) and no load (flat road).
    Anyone knows where to start search for the problem? It seems that some parameter are to aggressive, but is it flow, timing or something else?
    I want to record some data but what PID should I log?
    Are you using V7.5 or V8?
    May 2023
    Most comfortable with 7.5 but I have 8.0.
  1. Knock at low load
    By Saltsjoqvarn in forum Gen III V8 Specific
    Last Post: November 16th, 2023, 04:42 PM
  2. Replies: 8
    Last Post: February 13th, 2013, 03:07 PM
  3. Issues with engine stalling during low speed maneuvering
    By Wasted Income in forum Gen III V8 Specific
    Last Post: June 1st, 2012, 04:44 AM
  4. Is 45* too high for low load low rpm cruising?
    By the Dragon in forum General
    Last Post: February 13th, 2011, 01:43 PM
  5. Negative Timing in High Load and Low RPM areas?????
    Last Post: February 18th, 2008, 02:55 PM
