Results 1 to 10 of 10
Thread: Reading PCM
    Oct 2006
    Default Reading PCM
    Tried reading my PCM which was programmed by Street and Performance in Arkansas and efilive could not recognise the PCM. What happens if I just try and read anyways? I believe they use LS1 Edit.
    Oct 2004
    If it doesn't recognize the OS # then I expect it just won't read it at all. Is it not recognized or could it be that they locked the PCM?
    Andrew
    EFILive Crew
    Oct 2006
    I went ahead and tried to read the PCM after this warning:
    The PCM's hardware number: 0 ($ 0), is not recognised by EFILive.
    This may occur for the following reasons:
    -The PCM does not have a valid operating system or calibration.
    -This type of PCM has not been encountered by EFILive before.
    -This PCM is not compatible with EFILive.
    Continue only if you are certain that the connected PCM is supported by EFILive.
    I went ahead and continued and it started to read the PCM. I noticed that the calibration # was N/A, but I see all information from the PCM. I saved the tun file to my laptop and re-opened it and there was a calibration number in placed of the N/A. Do you think it's safe to go ahead and tune?
    Oct 2004
    I'd be concerned if it didn't have an OS #
    Andrew
    EFILive Crew
    Jan 2005
    I've send a PM to Paul and Ross about this. They should be getting back to you shortly.
    I'd be leary of trying a full flash, but see no problem with trying to do a calibration only flash.
    Oct 2006
    Excuse me as I'm new to this. There is a OS # 12212156 , but the Calibration # below that came up as N/A and after restarting the tuning tool it came up with a Calibration #. The BCC # two lines below that is question marks.
    If you send the *.tun file to me at paul@efilive.com I will take a look at it to see what is "wrong" with it.
    It sounds to me like this PCM had it vitals wiped courtesy of TIS at some stage. If you send the file to Paul then we can verify it is O.K
    Oct 2006
    Paul,
    I e-mailed you the tun file. Thanks in advanced.
    Rey
    Oct 2004
    12212156 is a valid OS so at least it's looking better for you...
    Andrew
    EFILive Crew
  1. HELP - PCM DOA after just Reading it
    By Olympic Fox in forum Duramax LLY
    Last Post: September 27th, 2009, 01:14 AM
  2. v2.06.10 5/25/09 firmware/Reading
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: June 9th, 2009, 09:51 AM
  3. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
  4. Reading the P12 PCM
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2007, 10:48 PM
  5. reading pcm's
    By ace68 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 02:52 AM
