Results 1 to 4 of 4
Thread: Open loop on deceleration
Hybrid View
    Feb 2005
    Default Open loop on deceleration
    I notice that my long term fuel trims always go negative (-8 - -12) when the throttle is closed and the car is moving. I notice that my maximum throttle position for idle long term fuel trims is set for 1.19. But my minimum throttle position at idle is about 6.7% could this be a culprit? Or look elseware?
    99 FRC 402 Twin Turbo
    Aug 2004
    looks like you have passed the amount of tps that the car can correct for. You probably opened up your throttle blade too much. When you guys turn the throttle blade up instead of drilling a hole, you have only a certain amount of turns before the car can no longer correct the starting tps %. So if you hit the point, Not drilling the throttle blade is not an option. You have to drill the Throttle blade and then turn the throttle blade for fine adjustments to get your steps inline.. so you have to back it out till it says 0 tps, then drill the blade to make up the difference..
    Oct 2003
    Default Re: Open loop on deceleration
    Quote Originally Posted by hpcubed
    FRC- C5/ETC (Fly by wire). Do the LTFTs actually update the PCM in a decel cell (20 or 21)? I didn't think they updated?
    Lifetime Member jfpilla's Avatar
    Quote Originally Posted by bink
    What cells are you in when you see the -8 to -12? Often cells 5 and 6 or thereabout, need VE adjustment to bring them in line with the rest and then use IFR's or MAF to bring all into line.
    Joel,
    I don't think they do. But in my car I never see 21 and only see 20 before the 02's are reporting.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  2. program is changing open loop to close loop
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2007, 06:38 AM
  3. Open loop or semi open loop still?
    Last Post: October 18th, 2007, 03:46 AM
  4. Semi-Open Loop Vs Just Open Loop
    By BowlingSS in forum Custom Operating Systems
    Last Post: April 14th, 2006, 05:25 AM
  5. Open Loop SD VS Closed Loop SD Advantages???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 12:25 PM
