Results 1 to 10 of 13
Thread: LS1 to LS2 cam sensor wiring help
    Feb 2006
    Default LS1 to LS2 cam sensor wiring help
    Hi Guys, I've recently installed a 402 stroker in to my car. (VY SS UTE) and i purchased the ls1 to ls2 extension cables fom racetronix to extend the cam sensor wiring harness from the back of the motor to the front.
    But shortly after the engine is running i get a P0343 DTC error logged for a CamShaft position sensor circuit high.
    If i unplug the cable, i then get a circuit low DTC P0342.
    I'm hoping that it's just a stuff up with the cable wiring, so im hoping someone might have a diagram of what the pin outs are on the Aussie LS1 wiring harness is as well as the LS1 & LS2 Cam sensors. (So i can make sure the wiring is incorrect to fix)
    1 thing i had to do to the cable to get it to fit into my ls2 sensor, was to use a soldering iron to melt a slot in the plastic to allow the plug to go all the way in to the sensor. Just incase anyone asks, yes the connecter is facing the right way as it has the clip going over the top of the sensor thingo to lock into place.
    P.S engine came out of another car and was working fine. So sensor should be okay.
    Any help would be greatly appreciated.
    Mar 2004
    i think i swaped the out side wires last time
    the tool for removing the pins from the plug can be purchased from a CAT dealer about $80
    & there is two LS2 cam sensors from holden one is big $ the other is cheap and worked for me both times
    I sent you a PM
    Geoff
    Lifetime Member Doc's Avatar
    Oct 2005
    Just to be clear, this was after a successful Crank Position Relearn?
    www.efialchemy.com
    www.greatamericancarwar.com
    Oct 2003
    I have been thru this. The cable (Katech) I got was 180* out. It is not right that you had to modify the connector to fit-
    Are you using the OEM cable extender that routes the cable to to the bottom of the cover?
    In the end you have to use a meter to check from the firewall comnnector to the sensor.
    PowrMax Performance
    100 mm PowrMAF
    Feb 2006
    You cant do a crank relearn with the cam sensor error anyway, so thats not it.
    I'm away from home at the moment, but when i get back I'm going to trace the wires in the cable to make sure they go from 1 end to the other with out crossing over.
    I will give ya call on friday NTAE if that's okay.
    Mar 2004
    Cool
    Have a look in side the plug on the cam sensor there is markings showing the pin config
    Feb 2006
    well doesnt look like im going to be home tomorrow, flight to perth has been cancelled due to bloody cyclone.
    Time to stock up on alcohol and dorito's.
    Oct 2003
    Quote Originally Posted by Tre-Cool
    The good news is the problem will wait for you.
    PowrMax Performance
    100 mm PowrMAF
    Mar 2004
    This is the cam sensor wiring from a holden Gen 111 PCM , inside the LS2 cam sensor plug is the pin outs for the sensor just join the wires and all good
    Feb 2006
    Well i checked the wiring this morning and the wiring went like this.
    A B C
    C B A
    I have now cut and resoldered the wires so they are now.
    A B C
    A B C
    No more cam sensor error, However im not happy with having to modify the $30 dollar cable!
    P.S there were no pinout numbers on my cam sensor. maybe i got the cheap one. :lol:
  1. Knock sensor wiring
    By 5.7ute in forum Conversions / Aftermarket Parts
    Last Post: August 18th, 2014, 08:38 PM
  2. Plx wiring help
    By blazinblue in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2008, 07:53 PM
  3. Gauge wiring
    By Durabroke in forum General (Diesel)
    Last Post: May 1st, 2007, 09:16 AM
  4. Need Help Wiring up Sm-AFR to V2
    By Chalky in forum General
    Last Post: March 11th, 2007, 05:36 AM
  5. wiring
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2006, 06:05 PM
