Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Adjust for tire size
    Lifetime Member Boost's Avatar
    Dec 2006
    Default Adjust for tire size
    I was able to adjust the tire size on my co-workers' '06 Silverado by following the EFILive tutorial. It corrected the speedo and the odometer, and eliminated the ABS light. I went to "Speedometer", clicked on "Parameters" and entered the values. It worked.
    Now I need to adjust my '06 LBZ 2500HD for the new 285/75/16 tires I'm running. When I go to "Speedometer" and "Parameters" the table that asks you for tire dimensions doesn't pop up. There are just 4 parameters displayed on the right, starting with "Tire Revolutions per Kilometer". Can someone point me in the right direction? Thanks.
    TORQUE SOUTH Tuning 125 VINs programmed
    2013 Buick Verano T 400+ lb-ft tq @ 26 psi with EFILive E39A
    1/8 mile: 8.933 @ 78.6 mph - world's fastest GM Delta platform
    2012 Chevy Cruze LTZ RS 200+ lb-ft torque @ 22 psi with EFILive E78 / T76
    40,000 MILES SO FAR OF RELIABLE AND POWERFUL 30 MPG TUNE
    www.torquesouth.com / www.gmtune.com / www.tstune.com
    I want to know this too, there has to be some way to calculate it as the LL8 has the same issue, there is no integrated tire calculator like the LSx engines.
    2013 Sonic RS Manual - 1.4L I4T E78, bone stock (for now...)
    New site! SE22 Performance Custom Tuning
    Oct 2005
    As an example, a Bridgestone Dueler REVO in your size will do 630 revs per mile. Divide that by 1.609 any you got revs per km.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    Dec 2006
    So are you saying that by entering that value somewhere in the Tune, we can correct the speedo?
    Oct 2005
    Yes....but not somewhere. You need to enter it in H0136 !
    I have not tried it as I don't have a LBZ or LMM but that is the only option you got right now!
    An all new speedo calculator is included in the next release. It should be available (pre-release) this week.
    Dec 2006
    Thanks! Sounds good.
    Dec 2006
    Does that mean that I the calculator that pops up for the LS1 Camaros and the 5.3 Silverados will pop up on an '06 SSR? I really need to adjust the speedo for 4.56 gears. Will I be able to do that as soon as I download the new version this week?
    Quote Originally Posted by Boost
    Yes
    And the LL8s too???
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 06:55 AM
  2. changed tire size, now ABS INOP
    By gcross in forum Gen III V8 Specific
    Last Post: November 11th, 2009, 04:18 PM
  3. help changing tire size!!!!
    By 2007silverado in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2008, 06:21 AM
  4. tire size and tune settings
    By brobradh77 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2008, 11:40 AM
  5. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
