Results 1 to 10 of 12
Thread: MIL for a LS1 conversion
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Default MIL for a LS1 conversion
    G'day everyone and Happy Easter!
    Got a question.
    If you were to do a conversion in which you put an LS1 into an old vehicle, what can be done to create a MIL (Check Engine Light)?
    I think the MIL on Commodores is illuminated by serial data sent to the instrument cluster.
    Any way to get around this?
    Any LS1 vehicle use a pin on the PCM as a direct connection to the light?
    Dave.
    Aug 2004
    Just hook it up to the pcm output. It puts out a NEG output. so the other end of the lamp goes to + ign.
    Jan 2007
    Thanx.
    I don't have a wiring diag as yet for the VT LS1, but I have got one for the VT V6, the V6 version doesnt have a pin for the MIL, it uses the serial data stream. That is what I was basing my assumptions on.
    Dave.
    Jan 2007
    The other thing I noticed on the same car model in the V6 version was that the low speed engine cooling fan gets operated by the body control module and the high speed was direct from the PCM.
    Same for the LS1??
    Dave.
    Aug 2004
    Jan 2007
    Is it possible though, the Australian LS1's have a different pinout?
    Its only a matter of code changes and some of the pins will have a different function.
    I'm getting the factory diagrams next week and will have a look.
    Dave.
    Aug 2004
    Dave, i dont think they would go thru that much trouble changing the software spare outputs to be different. Most of the inputs are all Hard component ins and outs. So they cant be changed without a board design. You should be safe. The only thing you need to do is make sure that you set up the tach output pulses and pullup to be the same for your tach.
    Jan 2007
    No Worries, I will still compare the pinouts next week just to be on the safe side.
    Thankyou VERY much for your quick replies and your helpful information
    Have a good Easter (when it finally arrives over there!)
    Dave.
    Jan 2007
    No MIL enabler pin on the Australian LS1 PCM, so there must be a difference
    Dave.
    Aug 2004
    If the same pin isnt being used on your pcm diagram then more than likely it is still being used. You can test by using efilive to turn on and off the mil light and see if the output is working.
  1. Please help with LS2 conversion
    By jasonsfbodies in forum Gen IV V8 Specific
    Last Post: August 3rd, 2010, 01:42 AM
  2. vz ls1 to l98 conversion
    By shane in forum Gen III V8 Specific
    Last Post: November 30th, 2008, 11:41 PM
  3. E-85 Conversion
    By vatman02 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2008, 02:53 AM
  4. 2k2 C.E.T/A LS1 to LS6 conversion
    By zentor in forum Gen III V8 Specific
    Last Post: April 2nd, 2007, 01:12 AM
  5. 3rd Gen conversion
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2006, 09:48 AM
