Results 1 to 10 of 12
Thread: Procharged C-6
    Nov 2005
    Default Procharged C-6
    We are having a problem with a Procharged 06 C-6 going lean around 4700. We have 60 lb inj and a kenny bell boost a pump and no mater what we do it wants to lean out.We know the maf is not maxing out and we even told the P.E Table to command 8.00 A/F with no change.
    Please help,Bill
    Junior Member Turbo595t's Avatar
    Sep 2005
    Quote Originally Posted by FFP
    Please help,Bill
    Hello Bill,
    What boost are you seeing at 4700? What is your Grams/cyl? What software are you using? It's my understanding that Efilive is read only right now, on the E38 computer for the 06 C6's or is it an 05.
    I would rather be Blown, then bottle fed
    Nov 2005
    My Mistake its a 05 but we are seeing 5 psi at that rpm and it just wants spike lean at that rpm
    Sep 2005
    If you could post a tun and a log, that would help.
    Nov 2005
    Talking Data log + Tune
    Here Is the Tune and the data log with it....the car is on the dyno right now so if there is any thing else you want to see log just let me know.
    Thanks for your help
    Bill
    Sep 2005
    Bill
    Hello Bill,
    After a quick look, does raising the Main Ve table at 4700 change the a/f if it does, I would keep going, if not check fuel pressure during the run.
    One othe thing I see which I don't think has bearing on this situtation but the MAF patch hasn't been applied and you are getting close to the max. I would apply this and do a full reflash just for saftey.
    Oct 2005
    My money is on your fuel pressure taking a dive.
    Whats injector duty cycle? You need to check FP too. Make sure its maintaining 58psi or close to throughout the run.
    2014 VF SV LS3 Maloo.
    Nov 2005
    Talking
    It Was the VE Table....FP was 58PSI through the entire run. This was our first Blown C-6 so we are still a little under the curve on the new stuff.
    Thanks for all of your help!
    Bill
    Sep 2005
    Bill
    No problem,
    Do you have a dyno sheet you could post? How is the part throttle?
    Brian
    Redline Motorsports
    Guest
    How did you guye make out?
  1. procharged 383 with '96 efi only runs 14's @ 96
    By tommytooslow in forum Vortec V6/V8 Specific
    Last Post: February 20th, 2009, 06:47 PM
  2. Procharged E38 08 LS3 Vette??
    By kbracing96 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 29th, 2008, 06:37 PM
  3. Can't get rid of KR on a Procharged 98 C5..
    By Redline Motorsports in forum Gen III V8 Specific
    Last Post: January 27th, 2008, 11:49 AM
  4. 1st ve autotune of procharged suburban
    By Chunx in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2006, 02:53 AM
