Results 1 to 10 of 12
Thread: o2 codes
Hybrid View
    Lifetime Member johnv's Avatar
    Jan 2005
    Default o2 codes
    Hi,
    A mates VT Commodore has been throwing o2 codes since fitting headers and removing cats(o2 low temp both banks etc).
    Can we alter any of the o2 cals to prevent this happening ?
    Cheers
    John
    John,
    VT's were notorious for throwing 'false' O2 codes.
    We've not added in the O2 diagnostic parameters, however, If you wish I can send you a tun file that was the 'official' fix from Holden to solve this issue.
    Jan 2005
    That would be great thanks Ross.
    Will I need the commercial version to load this tune ?
    Quote Originally Posted by johnv
    Sorry John,
    I was confused, the early VT updates were for false knock sensor codes, not O2 codes. I remember this happening to VT's when extractors were fitted, it never happened on my own VT so I never investigated the problem too far.
    Maybe a nice kind tuner on the board might give you the solution!!.
    Jan 2005
    Ross,
    yea he was told by dealer that he may need to move the o2s closer to headers.
    woundering if I were to upgrade to commersial and load a later model OS weather that might cure it as it doesn't seem to be as much of a problem on the later model Holdens.
    Ross,
    That I don't know.
    Mar 2005
    Silly question but have you tried replacing the O2's or swapping from a known working car just in case they were damaged during the install of the new headers?
    Jan 2005
    No, but both right and left o2s are throwing the same codes so unlikely they are both caput ! but not impossible !
    Ross,
    My VT spent nearly as much time at the dealer as it did at home, while it was under warranty. One thing the dealer told me was that the O2's were directly under the A/C outlet and that the water dripping onto the O2 sensor would cause it to not reach operating temp or damage it.
    I have no idea if that is true or not. I presume it can't apply to both O2's since both of them can't be under the A/C drain, but it could explain why the dealer wanted to move the O2's.
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    johnv,
    You said that you removed the cats. Did you install your secondary O2 sensors down stream of the primary 02's? If the secondary 02's differ from the primary O2 in activity level, then that tells the PCM that the cats are working. However, if the primary and secondary pretty much match in activity level, I would imagine that the code that would be "thrown" would be cat convert fail. Without the cats, the similarity in voltage outputs (primary and secondary O2) could trip some kind of O2 DTC.
    What is the approximate distance from the exhaust ports for cylinders 7 and 8 to the primary O2's in inches or Cm?
    All my best,
    Steve
  1. Dtc 040 & 041 ?? EGR codes...
    By Nor-Cal Nick in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 12th, 2014, 01:21 PM
  2. E38 & Codes
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: March 31st, 2009, 04:07 AM
  3. Error Codes
    By Chevy366 in forum FlashScan V2
    Last Post: November 28th, 2007, 04:22 AM
  4. Need help with a few codes.
    By slopokegtp in forum Gen III V8 Specific
    Last Post: July 27th, 2007, 12:36 PM
  5. abs codes
    By slimdad920 in forum General
    Last Post: July 9th, 2006, 01:34 PM
