Results 1 to 4 of 4
Thread: help! rich at idle
    Aug 2008
    Default help! rich at idle
    just installed a maggie sc mp112 then calabrated the ifr(b4001) for 42lbs/hr green tops @43.5 psi fuel pressure with 58 psi fuel rail pressure (std injectors supplied with sc)using injector calculator by red hot supra
    full flash new cos3 (01290003)last one was (12225074) then cal flashed the last specs of previous tune followed cos tutoral and ended up with 9.89afr at idle ???
    ls1, heads, exhaust, intake, maggie sc, 3.91
    Nov 2006
    if you are idling in the 50-60 kPa range, you might want to lower those values.
    they are quite high especially for cold start/open loop.
    not to hurt your feeling but, your VE table is "erratic" in some spots.
    LC-1 WBO2
    Aug 2008
    yer i thought it was a bit out of place mr prick,i kept on auto ve using bens but this recient log shows bens at 34.0-36.0 something is way out i can see the fuel leaving the end of the exhaust pipe...im thinking of reducing min pulse widths to 1.13 ive search the forum for related problems and found ifr values to be the culprit ill also min and defult pulse width to also affect for richness in idle?
    Aug 2008
    all apologies i found the problem "me" as a result of lack of concetration or retarditus i failed to modify the new rpm vs kpa b3647 through not following the tutoral sorry my mistake ..on the positive side revised a lot on injecters which made dialing easy for the green tops or bosch 42lbs
  1. New cam - rich idle??
    By Tomcat in forum Gen III V8 Specific
    Last Post: May 13th, 2008, 08:38 AM
  2. Rich Idle - Please Help!
    By white01ss in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2008, 05:09 AM
  3. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
  4. Idle is rich
    By zapp168 in forum Gen III V8 Specific
    Last Post: August 14th, 2007, 10:29 AM
  5. Rich idle
    By gcross in forum Gen III V8 Specific
    Last Post: January 10th, 2007, 02:35 AM
