Results 1 to 10 of 16
Thread: Convert ETC to cable TB
Hybrid View
    Aug 2005
    Default Convert ETC to cable TB
    I am helping a customer that installed a 5.3 out of a 05 truck into a 83 pickup. Can I delete the Electronic throttle control and use a cable throttle body? There are other issues with the IAC ..etc.. Does anyone have any wiring information help for this conversion?
    Xtreme Horsepower
    Tuners and Engine builders
    North Richland Hills, TX
    817-503-8947
    Jan 2007
    Yes. I have done this.
    I just bolted on parts to the newer longblock and then used an Operating System that didn't have fly by wire. My engine was a 2004 LM4.
    I changed the throttle body and wiring harness. I think most all of the sensors were the same. I think I played around with the steam tubes. It wasn't that bad. Small mods.
    I don't think the 05 5.3L engines have a different crank reluxor than 2004 5.3L engines. You would have to ask.
    Aug 2005
    I guess that you used a wiring harness and a 512 PCM. He was wanting to use the 1mb PCM. Is there a OS for the 12582605 PCM that supports the cable throttle body.
    Xtreme Horsepower
    817-503-8947
    Aug 2007
    Did anyone come up with an answer or is it a case of buy a 512 ECU?
    Jan 2007
    I bought a 6.0 out of an 06 van that was still cable throttle. I believe all the vans were cable throttle up to 06, if you found a file from a van it might have cable throttle. I thought I saw one on holdercrazy some time back.
    Jan 2007
    here is one from holder crazy, it's for an 04 with a 6.0 but you could try a full flash, the pcm might accept it, if it does then just find a 5.3 of the same os and do a segment swap.
    Aug 2008
    I did a transplant a couple of months ago (2001 DBW Denali 6.0ltr into Jeep Wrangler) The owner "INSISTED" on a cable operated throttle body instead of the drive-by-wire.
    I did a full re-flash on the Denali pcm using the OS from a 2001 Silverado 6.0 w/ cable throttle body
    Located and pinned out the signal's for the TPS & IAC. Fired right up...
    Also, I used the wiring harness from the Denali.
    FLASHSCAN V2 & AUTOCAL
    Aug 2007
    In looking over the various Calibrations it seems there are those with ETC in them even though they are cable, the diagnostic processes are different for the two, I am going to set up the diagnostic enablers as per a cable car in regards to TAC module communications, throtlle processes and IAC and see what happens.
    Joel
    Aug 2007
    That didn't work. Oh Well
    Aug 2007
    Had the 512 PCM opened up and there were no IAC drivers. The Calibration went in and ran fine but no idle motor control, there may be 2 512kb PCM part no's?
    Joel
  1. can anyone convert ant hpt file into efi?help,help
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: December 19th, 2009, 09:10 AM
  2. help! convert to ETC/drive by wire
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 08:46 PM
  3. Anyone willing to convert my PLX to serial???
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2008, 04:51 PM
  4. Convert 98 to 02
    By ChipsByAl in forum Gen III V8 Specific
    Last Post: June 26th, 2007, 05:23 PM
  5. LS1 Edit convert... first post with Q's
    By Chicago Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 15th, 2005, 08:11 AM
