Ok, I'm at a dumb mental blank.
If I want to change AFR@Idle, there is no specific table for idle right?
Use the AFR open loop table cells {B3605} that relate to idle right?
Also, just got a new (S/H) car and am in the middle of tuning it for SD, got the VE table all sorted and fueling is smack on. I have a problem with idle where if I stab the throttle (not in gear) the revs appear to over correct and swing backwards and forwards 100-150 rpm either side of the commanded idle rpm. It will continue to do this until I either go for a drive or hold the revs up around 1500-2000rpm for a few seconds and slowley release the throttle.
Any ideas on what this could be? I have made sure the timing has smooth transition between tables and even tried zeroing the under/over speed correction to stablise timing (because I wanted to eliminate timing as an issue, but I have put it back how it was)
I don't understand throttle cracker and follower settings, but I am guessing it has something to do with these.
If I put the Maf back in, this problem dissapears.
TIA
