I have a 98 camaro with a procharger. Should I install a 2 bar map sensor, split the ve and and commanded fuel tables then run sd open loop. Or download a 2002 camaro program, do the fuel gauge segment swap with a 2002 van and change the pins around. I would rather do the later so I can use custom op system 3 if it is even possible.
