Results 1 to 6 of 6
Thread: Part number for 2 pin Analog I/F
    Senior Member ArKay99's Avatar
    Apr 2004
    Default Part number for 2 pin Analog I/F
    I have been using a PLX M250 with my FlashScan and all was well. I misplaced the PLX and can't find it so I'm going to order a new one. However, I had the 2-pin WBO2 plug on the end of the PLX harness and that is also lost. I need to purchase one from a local electronic distributor so I can finish my tuning. :oops: What is the part number, and what are athe plug dims so I can cross-reference it?
    They are manufactured by Weidmuller (www.weidmuller.com)
    The part numbers are:
    2 way screw terminal: 1597360000
    3 way screw terminal: 1597370000
    Jun 2005
    Can I use the 2 Pin on a second Wideband 02 and plug it into the 3 pin area so as to not have to continually swap back and forth?
    2000 Corvette Twin Turbo
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
    Quote Originally Posted by vetteboy2k
    Yes.
    Jun 2005
    The Pids for the LC-1 are messed up some in the new release 3.1 stable. Keeping the same pid selection as in previous release I cannot log for my LC-1. I cannot validate the pids i normally do. By clicking on more info you can see the problem below. The pids are not looking for the correct info. The benlc1 is looking for pid for the LM12 and the pid LC1 is looking for voltage from the pid ext voltage 2.
    Base Efficiency Numerator 1 - LC-1 {CALC.BEN_LC11}
    Expression:
    factor = {CALC.AFR_LM12.AFR}/{GM.AFR
    is NOT valid because:
    Required parameter {CALC.AFR_LM12.AFR}, at position 20 is not selected.
    PID value cannot be determined because
    the following error would occur:
    Expression not valid: Required parameter {CALC.AFR_LM12.AFR}, at position 20 is not selected.
    AND
    Wide Band AFR 1 - LC-1 {CALC.AFR_LC11}
    Expression:
    AFR = {EXT.AD2}*10
    Required parameter {EXT.AD2}, at position 10 is not selected.
    Expression not valid: Required parameter {EXT.AD2}, at position 10 is not selected.
    Expression:
    V = {EXT.AD2}
    is VALID
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
    It is a problem with the sae_generic.txt file.
    I will fix it and issue a new sae_generic.txt file asap.
  1. Injector part number
    By GMPX in forum Gen III V8 Specific
    Last Post: June 23rd, 2009, 01:32 AM
  2. Corvette Servo part number???
    By ssvolvo in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 4th, 2008, 12:21 AM
  3. 06 LBZ PCM Part Number
    By SSTuner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2007, 11:42 PM
  4. New part number for E67 ecm?
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2007, 01:21 PM
  5. For Sale: New 512 kB PCM - Part Number 12200411
    By SinisterSS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 27th, 2006, 01:26 PM
