Results 21 to 30 of 32
Thread: Engine Oil Pressure PID
  1. #21
    Feb 2008
    The GM.EOPS PID is now back in the config file, however the LS1 controller returns the value as a voltage between 0 and 5 volts. The default conversion factor and offset for LS1 controllers is:
    kPa = V*1103.125-110.3125
    or
    psi = V*160-16
    Correction, the factors should be:
    1103.125/5=220.625 for kPa and
    160/5=32 for psi.
    The offsets remain the same.
    I recommend creating a calculated PID to display the oil pressure in kPa or psi. I have not yet worked out what the conversion factor is for other controllers (i.e. Duramax Diesel).
    For LS2 applications, use PID GM.ENGOILP which is returned in kPa. GM.ENGOILP is not available in LS1 platforms, which is why you need to create a calculated PID based on GM.EOPS.
    Warning: The factor and offset shown above are calibrated values and on some controllers may be different than the constants I described here.
    Have a LS1 Vx commodore... have been loging eops and can see the voltage in BBLlog... Can some one point me in the right direction to a thread that will tell me where and how to enter the above information... would love to read it in PSi and have a alarm in BBL for low oil when running the 1/4
    Shane
    I ate my bowl of Aussie rice for dessert, Main course was imported rice...
  2. #22
    Example of how to create a calculated PID:
    http://forum.efilive.com/showthread.php?t=132
    Another one:
    http://forum.efilive.com/showthread.php?t=10
  3. #23
    Feb 2008
    Lol going to have to do so some more reading crap that is confusing...
  4. #24
    Sep 2003
    I played with this in the Options.ini file, but the V2 does not seem to know how to subtract. I haven't tried it lately and don't know if it would work now.
    *PCU
    ; PID Caption Prec Units Op Factor Offset
    PCM,EOPS, EOPS, 1, psi, *, 32.0, -16
    Or you can add this to the C:\Documents and Settings\Owner\My Documents\EFILive\V7.5\User Configuration\calc_pids.txt file.
    # Add slot definitions here
    *CLC-00-043
    PSI 0.0 150.0 0.0 "({GM.EOPS}*32)-16"
    CALC.OIL_PRESSURE F043 CLC-00-043 PSI Testing "Engine Oil Pressure"
  5. #25
    Quote Originally Posted by Ninety8C5 View Post
    *PCU
    I tried this just now and it appears to work ok.
  6. #26
    Sep 2003
    It seems to work and is reasonably close to the 'Oil Pressure' gauge. The digtal readout on the car seems to read a little lower, but close.
  7. #27
    Senior Member Wolfie's Avatar
    Dec 2007
    Has anyone tried using the calc_pids.txt file?
    I got an PSI error, so changed PSI to psi.
    That worked, but then I get a slot error.
    Have a 2007 Express with a LQ4 6.0
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
  8. #28
    Mar 2007
    so did i read this correctly that even with a custom pid we can not use this on a 2000 F-body?
  9. #29
    Quote Originally Posted by Cablebandit View Post
    Yes correct, for F-body, the oil pressure sensor feeds the IPC and not the PCM.
  10. #30
    Is EOP working (for C5 Z06)...?
  1. LS1 Engine Oil Pressure- HTF do i log it?
    By Tre-Cool in forum General
    Last Post: September 29th, 2008, 01:41 PM
  2. oil pressure pid
    By HINDZY in forum Gen III V8 Specific
    Last Post: May 17th, 2008, 01:59 PM
  3. oil pressure pid
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2007, 02:27 AM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. Fan A/C Pressure
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2007, 10:19 AM
