yeah that basically give me the same info for the inputs, gave me 3.161175, which EFILive would round up to 3.16406 anyways. thats a good spreadsheet though, I'm keeping that....
on another note...JACKPOT!
I found this site: http://www.carprogrammer.com/
where that SVO vs multec voltage offset chart came from, and it just so turns out that the GM multec settings he listed look like they're from his LT1 camaro. so those should be the exact same kind of injectors I am currently running, I'm going to pull over that data into {B3701} and hopefully that should help.
also there is TONS of info on that site if you cruize around. definantly worth looking around.
also, I haven't looked at one of your tunes, but remember that your IFR should be a straight line since the FP regulator is manifold referenced (or I believe it is for your marine intake).
