So I was driving along and the maro just shut off. Great fuel pressure, no spark or injector pulse. Was able to flash computer, grounds all look good. So I went out to mess around with her again and she fired right up. So I logged a little bit a data and she died. Wont start again. Im thinking bad crank sensor, but if you can look at the log and see if you see anything at all. Im lost.
