Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: ETC Pedal Response
    New Member 05_Sierra_6.0's Avatar
    Sep 2007
    Default ETC Pedal Response
    Does anyone know the limits for tables B2307, B2308 and B2702. There is a warning about not adjusting too much but how much is too much?
    2005 Sierra 6.0 L
    AEM Brute Force CAI
    Bassani Mid Length Headers
    Dual 3 in. Flowmasters to custom 4 in. tailpipe
    80mm BBK Throttle Body
    Harland Sharp 1.8:1 Rockers
    Sep 2007
    Default Hello?
    Anybody have a clue about these tables? Anybody?
    2005 Sierra 6.0 L
    AEM Brute Force CAI
    Jan 2007
    I don't know much at all about ETC but If airflow goes over a certain value over stock the PCM based on real throttle position it will see it and set a code thinking the ETC has failed.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Has anyone played with these settings in Aussie VZ LS1's with any positive effects? problems - how far away are they from standard
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    The most you would want to do is grab the values about zero and below 100 and blend the curve with the blending function.
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Aussie cars are VERY sensitive to changes, like 2 - 3 % tops, whilst some US models you can go crazy, there is no exact science. You will know if you have gone too far as the PCM will go in to limp mode, that can take 10 - 15mins of driving though.
    Sep 2007
    I increased my ETC response by 3% with no issues. It responds much better. Thanks for the input Ross.
    2005 Sierra 6.0 L
    AEM Brute Force CAI
    Aug 2006
    I don't have any Electronic Throttle vehicles but, which tables did you change by 3%. I would like to know for future reference.
    Jeff
    Sep 2007
    Quote Originally Posted by Lextech View Post
    Jeff
    I adjusted the values in table B2307. This table is only available when the V2 is plugged in to a computer and a file is loaded from a vehicle that uses ETC. I adjusted all of the table values from 3.13 pedal position to 93.75 pedal position up 3%.
    2005 Sierra 6.0 L
    AEM Brute Force CAI
    Aug 2006
    Thanks for the info
    Jeff
  1. DBW pedal and TAC module differences
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: September 17th, 2009, 05:09 PM
  2. Accelerator pedal problems
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 21st, 2009, 10:49 PM
  3. help with gas pedal
    By litreddevil in forum Petrol / Gas
    Last Post: January 11th, 2008, 03:41 AM
