Results 1 to 2 of 2
Thread: Help Repaired V2 now keypad issue
Hybrid View
    Jan 2006
    Default Help Repaired V2 now keypad issue
    Hi, I had a memory issue see this thread http://forum.efilive.com/showthread.php?t=8297
    and send and received back my V2 , with Firmware 2.05.17 and Bootblock 2.05.08, Efilive explorer connect no problem , and upload from 1 ecm to my laptop no problem.
    Now during the first 1-2 minutes the V2 is power on the keypads keys F3,up arrow,ok,down arrow don't work at all except if I press on one of those key with a lot of pressure ( I mean a lot ) then it start working then sometime pressing normally the arrow keys will make it jump 2 line at the time.
    I try with V2 to pc only , V2 to car only , upgrade Firmware to 2.05.17 but no change.
    Modpcm
    Quote Originally Posted by modpcm View Post
    Modpcm
    That can happen on some units due to a mis-configured Settings.dat file immediately after an upgrade. Run the EFILive_Explorer program, check in the [Config] tab page and delete the Settings.dat file. Then power off FlashScan, wait 10 seconds, power it up again - the keys should work normally again.
    If that does not fix the problem, please contact Ira at Fish Tuning who did the warranty work.
  1. 427 L92 a4 GTO issue
    By 10secvette in forum Gen IV V8 Specific
    Last Post: January 26th, 2014, 11:32 AM
  2. DTC issue?
    By Cougar281 in forum Duramax LLY
    Last Post: June 2nd, 2008, 09:32 AM
  3. New Issue
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 16th, 2006, 10:07 PM
