Did you look at my last post in this thread?
http://forum.efilive.com/showthread.php?t=7726
Yeah thanks thunder, mine is the same as your bar i pulled power directly from the main chip...
Once again though...Still dosnt explain why it works perfectly in Pass threw using iether Serail or Analog and BBL Analog but not in BBl serial..
I ate my bowl of Aussie rice for dessert, Main course was imported rice...
I wired mine just as Blacky describes here:
http://forum.efilive.com/showpost.ph...7&postcount=10
2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
Check Out My Latest Tune File: HERE
that is for a Lc-1 isn't it???
Anyonce again... If it is the wiring why does it work in Pass threw
Okay i am not the most technicaly minded when it comes to electronics, Maybe i havnt ticked all the boxes somewhere.. Do you guys see what i am trying to say... If it is the wiring why does it work in pass threw etc etc... the problem only show when bbl loging using the serial imput..
Yes it is. Read down in Blacky's post.
---cut---
RJ12 pin 5 goes to phono base
RJ12 pin 2 goes to phono middle
RJ12 pin 1 goes to phono tip
---cut---
Do you have the terminator plug in the other input on the LC-1? Also, you need to have both Com-IN and Com-OUT set to Wideband O2 in the V2 menus.
Aside from that, I dont know what to tell you. Mine worked the first time I made the cable and plugged it in. Reply if you want with all the settings you have chosen in your V2 settings menu. Maybe there is something that is not quite right.
I have logged it with BBL Serial and Analog, no issues.
Just a few thoughts to help:
-The serial line uses Channel 1 of the LC1. Is Channel 1 programmed w/ proper voltages/AFRs? I know you said it works with Analog, but both wires?
-Are you using -, WO2AFR1 or W02AFR1 in your options.ini w/BBL?
-Is FlashScan set to Innovate in the settings option? Don't do what I did, accidentally hit enter and end up on Innovate(2) instead of Innovate(1).
-Do both Analog wires give the same output?
- When in BBL mode and you flip the key on, do you get the Free Air
display?
07 Silverado DMax Classic
02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
Old Engine: 1/4mile = 9.6/146 New Engine:?
EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
COS5/12212156 For 2002 Z06 Manual Vette
Let's bring this one back on topic. The spiking AFR thread is here
