Paul,
Thats a good idea, because I don't quite know how to construct the formula. Also, if you would, look on the previous page at some of my questions on calculated PID's.
Thanks,
Steve
Paul,
Thanks,
Steve
Joe, I have the same unit and did it as a kit last year. I'm sure we can figure it out and Paul can maybe workup a Tech-Edge V1.5 PID? Paul?Originally Posted by jfpilla
http://techedge.com.au/vehicle/wbo2/wblambda.htm
Here's a brief "tutorial" on creating calculated PIDs
http://efilive.com/forum/viewtopic.php?t=1142
That would be greatly appreciated.Originally Posted by EFILive
Never was any good at Maths.
Would it easier to define a formula to get to line with a better fit by only using the points between 10:1 and 12.5:1 (approx.)? Yeah, I am math-challenged as well. :lol:
...based on the formula:
(x^5)/700 + (x^4)/650 + (x^3)/650 + (x^2)/50 + x/1.06 + 8.41
Here are the changes that I made in the Calc_Pids.txt file, using the Calc_pid construction thread referenced in this post:
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
AFR 8.41 19.44 .1 "({EXT.AD1}*{EXT.AD1}*{EXT.AD1}*{EXT.AD1}*{EXT.AD1 })/700 + ({EXT.AD1}*{EXT.AD1}*{EXT.AD1}*{EXT.AD1})/650 + ({EXT.AD1}*{EXT.AD1}*{EXT.AD1})/650 + ({EXT.AD1}*{EXT.AD1})/50 + {EXT.AD1}/1.06 + 8.41"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.ELH_AFR F001 CLC-00-001 V Fuel "Ext Wideband AFR"
Does this look correct?
What about a linear output like the LM1
LM1: result = volts / .5 + 10
That one is built in to EFILive, just display {EXT.AD1} using the AFR units.Originally Posted by Dirk Diggler
You can see the "formula" in sae_generic.txt as this:
This is the basic definition for both {EXT.AD1} and {EXT.AD2} PIDs and it converts the raw A/D value into both voltage and AFR.Code:#Units Low High Fmt Op Factor Offset #------------ ------------- ------------- ---- - ------------- ------------- *UNM-16-901 V 0.0 5.0 .2 / 204.6 0.0 AFR 10.0 20.0 .2 / 102.3 10.0
Note, the SLOT name of UNM-16-901 defines the raw data as
UNM=Unsigned numeric
16=16 bit data
901=unique sequence number
The raw A/D values comming in from the external A/D pins is a value between 0 and 1023 (using a 10 bit A/D converter) which represents 0 to 5.0 volts.
Due to voltage protection built into FlashScan the highest voltage that can be recorded is 4.8V, but that does not alter the fact that 1023=5.0V
The voltage is defined as:
V=N/204.6+0 where N is the raw digital value in the range 0..1023.
To convert to AFR using AFR=V*2+10, use:
AFR=N/102.3+10
For simple linear values, you can add PID definitions like this to the calc_pids.txt file. Just make sure you use a unique SLOT name and a unique PID name.
You may reference existing SLOTs in sae_generic.txt if one exists that is the same as what you need. Most standard SLOTs are already included in sae_generic.txt.
Note: to reference the RAW data values in your PID definition, use the following reserved PRNs:Code:#Code PRN SLOT Units System Description #------------------------- ---- ------------ ---------------- ---------------- ------------------------------------------ EXT.AD1 F400 UNM-16-901 "V,AFR" External "Wide band O2"
F400 = {EXT.AD1}
F401 = {EXT.AD2}
F402 = {EXT.EGT}
Blacky,
Got everything to work...thanks!!!
....and thanks to everyone else that lent a hand.
I found a neater exponential based expression, but EFILive does not support exp() yet!
exp(x)/25 + (x^2)/30 + x/1.2 + 8.41
The next release will have the following functions added:
exp()
log()
log10()
pow()
sqrt()
