The trigger (ground) wire goes to Pin 42. On your PCM, Pin 33 is internally wired for another purpose; on the trucks, the PCM does not support 2-speed efan operation until 2003 and the redesign of the AC climate control circuit.
Mr. P.
Mr. P.
FLASHSCAN V2 & AUTOCAL
Pin 33 in your PCM is used to control the recirculating door (climate control); when Delphi made that PCM that pin is grounded all the time. We have run into the same issue 3 times now installing efans into pre-2002 trucks, I resorted to a custom relay box with the high trigger wire plugged into pin 42 and the low trigger wire activatedby the AC compressor.
If your AC system has the simple AC high-side safety switch then your PCM will only support one fan circuit; if you have the later (2003+) high-side pressure sensor then your PCM will have both the internal circuit and OS support for dual-speed efans.
Mr. P.
Is your A/C all gassed up to pressure?
Yes, AC is gassed up... I've tried different pressure settings and fan is still on....
When using that OS select the "Auxillary Fan" instead of "Series Parallel Fans" and it will work fine. Just ignore fan settings for fan #2.
2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
2002SS Camaro LS7/427 with stock suspension setup
2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
I already tried that, no luck though....
Missed that in your posts. Don't have access to my laptop right now but I have done that year model. It was pin 42 and I used Aux Fan setting but can't say which OS right now. The OS can make a difference.
I suggest taking a digital volt meter from 12v to pin 42 and see if indeed the PCM is turning the fan on.
