Results 1 to 10 of 12
Thread: Converting serial Lambda to AFR
    Nov 2006
    Default Converting serial Lambda to AFR
    Can we manually change the multiplier for serial Lambda 1 to AFR
    or is that set in the WBO2?
    LC-1 WBO2
    Lifetime Member Mr. P.'s Avatar
    May 2007
    What WB are you using?
    My guess is that the number is coming directly from the WB, and just being 'passed-though' the V2. I had the exact opposite problem, my WB reports AFR and I created a custom PID to display EQR from it, this is what I show on my dashpage now.
    Mr. P.
    V2 also provides serial EQR and serial Lambda (they are the inverse of each other) as queried from the wideband...
    My understanding is that the wideband assumes stoich to be 14.7.
    I pm'd Paul for more guidance (he's on holidays right now).
    Nov 2006
    This is what I figured.
    IMO we should be able to set the AFR that L1 represents.
    If I want to run E85 L1 will be 14.7 when it should be 9.7
    Otherwise I'll just make a calc_pid off of serial Lambda.
    LC-1 WBO2
    I get EQR and/or Lambda from the wideband, and I factor stoich AFR later when viewing logs.
    Nov 2006
    You mean add it or is there a way to change it?
    LC-1 WBO2
    I add it later as a calc pid (I use 14.63 as stoich, same as my B3601)...
    or from a cheat sheet with a few AFR's printed on it...
    I don't really use AFR much anymore.
    Nov 2006
    That's what I figured.
    TY
    LC-1 WBO2
    Redline Motorsports
    Guest
    I do the same. took a while to succomb to lambda but I like it. Still look at AFR though at WOT just for a sanity check!
    Nov 2006
    Yeah, but another thing I noticed is commanded AFR is not exactly what should be.
    Stoich and PE are off slightly from what is in the tune.
    LC-1 WBO2
  1. lambda vs a/f
    Last Post: September 22nd, 2009, 10:12 AM
  2. How do you log WBO2 lambda instead of AFR?
    By waveoff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2009, 08:03 AM
  3. Bug > Serial WBO2 Lambda and EQ mixed up
    By nevinsb in forum FlashScan V2 BB Logging
    Last Post: June 16th, 2009, 09:57 AM
  4. Lambda
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2006, 03:42 PM
  5. Any way to view fuel in AFR instead of lambda?
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 05:36 AM
