Once you get the 2/3 Bar MAP setup, you need to copy the 1 Bar VVE table to the 2/3 Bar VVE table and start from there. Once you get into the 2/3Bar table (2 Bar is min for FI applications), then you can actually setup the VVE table to command the proper fuel values.
