Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 58
Thread: 0411 conversion issue
  1. #31
    Member Whipped383's Avatar
    May 2011
    Just a thought and Im sure its been thought of but what happens if you take the cos file for the working s10 file you started with then do the segment swaps?
    97 K1500, 383, 4L60E, Whipple, Stock 14 Bolt with 3.73, EFILive V2, 0411, Marine, #42 Injectors, H-Boost, LC-1, Coming Soon: Intercooler, Trutrac, 4.11 gears?
    03 K2500HD, 8.1 and Allison, Stainless works long tubes, Intake mods
  2. #32
    May 2011
    Anyone? Does the s10 file this was derives from have a different os number?
  3. #33
    May 2011
    So I just did the cos3 upgrade and the low works! I dont know how or why but it does. I still have some stuff to iron out with the cos and alot I dont understand with it and it runs like poo but made it to the end of the street in low and overdrive
  4. #34
    What the ?? Post up the base and the upgraded COS file, Im sure there are guys who want to be able to do this!
  5. #35
    +1 please post immediate pre-COS base file and COS file.
  6. #36
    May 2011
    Ill post some up tonight is anone willing to test it?
  7. #37
    I'm sure someone with a 4x4 will show up.
  8. #38
    May 2011
    Ok here are 3 tunes the base cos, the base working 4x4 tune, and the 2 merged togeter. its not totally set up and still needs work and if anyone wants to give me pointers thatd be great like I said im a newbie at this. Please do not re distribute these but feel free to use them and test them once others have tested them and verified that they work then use them at will. I just dont want these all over the place If they arent working properly. The COS3_0002 is the one thats partially set up that I tested the low with and the one I need pointers on
  9. #39
    May 2011
    Well I hope they work for you guys I just emailed the 0002 tune to aloicios and he did some work on it and sent it back labeled as a 0004 I did a full reflash with it because I had put the old os back in it, and the low didnt work. So I did a full reflash with the 0002 file and the low worked so I then did just a cal only flash of the 0004 tune over it and the low still worked. Dunno what happened there but its wierd
  10. #40
    Hmmm, did he fix the out of range cells that appear when you open the 0002 file? Maybe that part of the COS overwrites the 4 LOW settings...
  1. 0411 controlling the fans issue...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 06:50 AM
  2. 1996 7.4 with 0411 PCM
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: June 5th, 2010, 01:22 PM
  3. Need Help 0411 PCM
    By rsicard in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2010, 09:00 AM
  4. 96 to 01 '0411 conversion; S10 4.3 newb ?
    By overS10ded in forum Vortec V6/V8 Specific
    Last Post: November 20th, 2009, 04:43 AM
  5. LBZ conversion issue?? Reduced Engine power??
    By heathgu in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 14th, 2007, 12:17 PM
