Results 1 to 10 of 10
Thread: Very odd fuel pressure table-Medium Duty-LBZ
    Default Very odd fuel pressure table-Medium Duty-LBZ
    Maybe someone will know what this is all about, specifically the maxxed out fuel pressure command at minimal fuel. Appears only on the Medium 4500-5500 OS.
    Attached a copy of a stock file. B1001 is base pressure
    Must be noisy as heck. My question is, does anyone have a plausible explanation for why such high pressure is used at near idle ops?
    Custom Tuning Services
    image.
    That table is being displayed wrong which is quite odd given the same OS on normal truck looks fine.
    I'll have to inspect the file a little closer, it's probably just another wonderful "Boschism" we'll have to find a work around for.
    For now, I would not change any values in the table.
    I have 3 OS's for the LBZ medium duty, all showing same. Do you need me to email them?
    I intentionally posted the ...128 for that reason.
    Jan 2008
    You do remember that most (99.9%) of EFILive users and tuners use the last 4 digits of an OS number, right?
    Yup. Just stubborn.
    Anyone have any thoughts about this? I want to get this off my desk.
    The file you posted will be fine to work with.
    Ross, is it accurate as far as you know?
    Mar 2009
    What was teh outcome of this issue? Is the numbers in the table correct or not? I'm considering using this OS for a dual tank BURB I'm helping somebody with since I haven;t found a 3500 cab and chassis dual tank one yet?
  1. LBZ-Odd Rail Pressure Drop
    Last Post: May 7th, 2010, 11:55 AM
  2. Question on a LBZ fuel rail pressure?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 07:45 AM
  3. P0606 update-LBZ stalling-Fuel pressure anomolies
    Last Post: July 29th, 2009, 04:49 AM
  4. Fuel pressure sensor scaling for LMM/LBZ
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 4th, 2009, 11:21 AM
  5. Reading oil pressure and fuel temp on a LBZ
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2008, 09:29 PM
