Results 1 to 10 of 12
Thread: What is wrong.... Dyno run....
    Senior Member Behold's Avatar
    Apr 2010
    Default What is wrong.... Dyno run....
    Right..... Other than my injectors clearly toping out at about 5000 RPM why am i only producing 284 RWHP...... It is running a little too rich at 10.5/6 is on WOT but still surely LS1 with 5psi should be well in to the 300's at minimum.... will it be just the fact my injectors are over 80% when it needs it.....????
    Attached is the run, tune and scan. My Commanded to Actual AFR is not too far out but not 100% hence the 10.5 at top end... its also a smooth curve.
    Thoughts???
    Dyno Run PE115.efi
    V7.2 - PE115-SD-2BAR-COS5.ctd
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    V7.2 - PE115-SD-2BAR-COS5.ctdwhat type of blower? non-intercooled maggie or vortech? it heats up like a mofo way to quickly to be intercooled.
    low timing, fat mixture wont help in making power that's for sure.
    i have auto ve'd the boost table from that log and adjusted the spark map and bias tables.
    Sep 2008
    A bolt-on and tuned LS1 will make that power and I'd suspect a tuned C4B engine to make around the 290rwhp+ mark, so there is clearly something amiss there if you are pushing 5psi through it and only making what you are making. What FI system are you using? I suspect it may be one of the old CAPA type centrifugal blowers???
    swingtan
    Guest
    OK, I'll go out on a bit of a limb here, assuming all the mechanicals are OK and apart from the obvious injector issues and the over richness,
    1. The rich mixture may be causing a "rich knock" condition, which is pulling spark, dropping power.
    2. Looking at the log, it seems that VSS takes a jump at 3800 RPM, possibly indicating wheel spin on the dyno. At this point, the engine gm/Cyl figure also drops. (frame 971)
    3. IAT is quite high, limiting the amount of spark advance you will be able to run.
    Work on the fuel delivery first. Don't bother trying to dial in the spark when you know the fueling is off. Once the fueling is good, then work on the spark. Add an intercooler or get a bigger / better one to help control the IAT's. I'd expect somewhere around the 450+HP from that setup.
    Simon.
    Apr 2010
    Thanks for that. Just so I understand. I get you have told the spark table not to correct as early on when the IAT is high. How did you AutoVE when the LTFT are active accuratly? Also can that be trusted while im leaning out?
    As to the High/low spark tables how have you chosen them figures?
    The blower is a capa kit. It is non intercooled (Next step before putting more PSI through it) and its using a V2 SQ vortech charger. Its an 8 rib drive and on that PSI should not be slipping. (I think the fact im hitting 135kpa proved its working)
    Is there anything to start monitoring to aid understanding this issue more?
    Simon.
    I was expecting close to 400 RWHP as 300RWHP should be easy on a NA engine. The car runs well and i can only guess its all running well from the fact nothing seems off. There is no untoward sounds both normally or using a screwdriver on different areas of the casings ETC.
    Based on this I want to sort the injectors ASAP but the injectors I got with the kit seem to be impossible to get the data for to put them in the car. My next question on here will be what injectors are recomended with good results.
    With this I can start working on the finer points of this issue.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Sep 2008
    Why don't you specify the injector size and any other modifications to the car, so that people can provide some enlightened advice? At the moment, we're all guessing. Further to that, as Swingtan stated, your IATs are very high - the time for a decent intercooler is already here.
    Good luck
    Apr 2010
    Macca
    Good question..... Im running standard injectors that I believe are 22 or 24lb/hr @3bar but im not 100% sure. Im apparently commanding 140% at the worst point.
    Im assuming if im going to buy new injectors 60lb/hr seem sensible.
    My car is not that modified at the moment but it will be a long standing project.
    NOW
    Cat back exhaust
    5PSI Vortech V2 Charger
    Next soon steps in order
    Injectors!!!!
    Intercooler, better pipework and new BOV's
    Larger pulley (7-8psi)
    Remove Cats
    Future
    Headers
    Pistons/rods/cam
    Larger Pulley
    Injectors??? Maybe...
    All of this is high level other bits to suit will be done as required (e.g new shells when i do my pistons)
    Its my current plan anyway!
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    you need to put an intercooler on it right now and then put a set of 60lb injectors on. with 5psi of boost you should get away with the standard pump until your breaking the 400rwhp mark. the good thing about the vortech is the power will be build linearly and thus the pump can sustain the pressure fine around the 11.8 afr mark.
    Sep 2008
    Yep, injectors and intercooler would be a very wise decision in the immediate term.
    cheers
    HSV Senator 300 - the Classy C4B...
    C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
    308rwkW(413rwhp)
    Apr 2010
    They both are a top of my list job. the injectors more so so that it does not lean out. the Inter cooler is next up. Im looking at what i need pipe wise to ensure it can be fabricated.
    So what 60lb injectors do we have all the data for and are worth using.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
  1. I think i did something wrong!!
    By 02Tahoe28 in forum Duramax LB7
    Last Post: October 2nd, 2008, 07:44 AM
  2. HELP!!!! VE seems wrong, after using RR
    By vxleather in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 26th, 2008, 08:30 AM
  3. Can anyone see anything wrong here???
    Last Post: February 4th, 2008, 09:29 AM
  4. What am I doing wrong?
    By wildwhl in forum Black Box Logging
    Last Post: July 7th, 2006, 12:55 PM
  5. Dyno success on Dynolog Dyno
    Last Post: April 2nd, 2006, 12:31 AM
