Using Tune V7.5.7 and scan V7.5.7 (COS3 with V1 cable) for Speed Density
From EFIlive Scan V7.5:
Can't we just take from the F11 / open new map file use the "autoVEprimary. map" file? -and then use the (F8) open existing PID file ( eg. Autove_autronic.pid ) instead of selecting PIDs and creating a Map manually as suggested in the AutoVE tuning tutorial? (revised dec 2008)
This seems more plug and play (PnP)
It can even go further creating an AutoVE SD and a AutoVE MAF PID file. (and maps?) The only other variable would be the WB02 used and for that it can be added after opening the preconfigured AutoVE PID SD/MAF file.
Is this plausible?
