Hello Everyone,
I am noticing weird issues with my TPS readings when I a logging.
There are times when I am driving normally and I let off the gas completely and TPS pid will read 0% throttle position but then there are times I let completely off the gas and the TPS pid will read 1.6% throttle position or as high as 2% throttle position. It causes the car to idle high as well.
I am only logging 14 pids. I am away from the computer I use to tune so I can't send a file for a day or so.
I've tried resetting the TPS by unplugging and plugging it back in but it is still doing it.
Has anyone else experienced this before? I might just buy a new TPS in case.
Thanks,
Glenn
