In one of the RC versions we added the option to specify a stoich value that is used to convert from Lambda (i.e. the value from the WO2) into AFR. It had a bug that caused the stoichiometric value to default to 0 instead of 14.7 IT was corrected in a later firmware version.
You should check that the stoich value is set correctly in the settings for FlashScan for the fuel you are using - as shown below:
If it is/was set to 0 (i.e. has never been set by you) it will now correctly default to, and show up in the settings, as to 14.7 instead of 0.
