Results 1 to 10 of 15
Thread: Fuel Injector Timing
    Nov 2007
    Default Fuel Injector Timing
    Can the fuel injector timing be changed ?? I.E. on a sequential fire system can
    the fuel be fired sooner or later.
    Thanx
    -Justin
    Lifetime Member Aloicious's Avatar
    Nov 2007
    unless I'm mistaken, B3702 is precisely that.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Redline Motorsports
    Guest
    Yes you can under the injector tab and it's based on coolant....at least with E38.. Dont have my laptop w me.
    Nov 2007
    Quote Originally Posted by Aloicious View Post
    I think you are correct, but it's based on coolant temp. I was thinking something
    based on RPM so that maybe at high RPM you could advance it a little to keep up
    with the intake valve opening ??.......just an idea.
    Thanx
    -Justin
    It's not as simple as keeping up with the intake vale opening... at high RPM the injectors will be open for longer than the intake valve is open, there is no way to spray the whole load while the valve is open, the spray will hit the closed valve.
    There is also wall wetting/evaporation effects which the PCM models since the spray hits the port walls and not just the valve.
    Jul 2009
    you have a great idea as i agree with your thinking... but being based on ect i dont see how this would be possible to be zero'd in on engine rpm... maybe someone will chime in to clear this up for us i have thought about this alot
    2004 joe gibbs, rcsb, t-56 6 speed, 4.8l supercharged 10#, cam, bolt-ons, etc
    1987 gnx
    d-21 allis chalmers 3000 hp 504ci on alcohol
    2004 dmax tow pig
    Jul 2009
    their is noway to start the injection event sooner?
    1987 gnx
    2004 dmax tow pig
    Nov 2007
    Thank you Joe,
    So basically you are building a puddle behind the valve that falls into the
    cylinder when the valve opens, then I guess it really wouldn't matter.
    So sequential fuel injection is really only useful at low speeds ?
    Thanx
    -Justin
    The puddle has various characteristics... some of it will evaporate before the valve opens again, some of it will fall into the combustion chamber and evaporate there, and a few other modes;
    also note that if for some reason the PCM can't figure out the crank/TDC phase on startup, it will fire the injectors in batch mode.
    swingtan
    Guest
    Talking E38.....
    {B1205} Injector timing vs. ECT
    {B1206} Injector timing vs. RPM
    And I believe that the timing in in degrees from TDC on the firing stroke.
    As joecar says, the required injector pulse width will be longer than the inlet valve is open for and altering the timing will mess with fuel dynamics.
  1. Strange injector and timing behaviour?
    By DrX in forum Gen III V8 Specific
    Last Post: July 19th, 2011, 07:44 AM
  2. injector timing
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: January 18th, 2010, 01:17 AM
  3. Injector Reaction Time - Effect on Timing?
    By VegasDMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 6th, 2009, 04:52 AM
  4. L-29, 0411 computer and injector timing
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 21st, 2009, 04:08 PM
  5. injector Timing {B3702}.... when to tune?
    By Goldfinger911 in forum Gen III V8 Specific
    Last Post: February 22nd, 2009, 08:10 PM
