Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: cos help
  1. #21
    In the text box (the log of what happens when you flash), can you copy all of it (place cursor in box, do CTRL-A CTRL-C) and paste it here (CTRL-V) in a reply to this thread...
    ( I want to see the flash portion of the log )
  2. #22
    Oct 2006
    If you have any aftermarket radio, alarm system, pull the fuses for them.
    2006 Trailblazer
  3. #23
    It is what Taz explained in post #11.
    http://forum.efilive.com/showthread....l=1#post195148
  4. #24
    Ok, cool, thanks Paul.
  5. #25
    Dec 2013
    cos is now loaded and cal is flash in. read the file and the cos is there. adjusted what I needed and now ready to tune.
  6. #26
    Be sure to fix B3647 and any out-of-range A00xx cells.
  7. #27
    Dec 2013
    hey joe, i was looking and reading the user note in A0011 and it reads that this is used on (j2,pin56) shouldn't it be C2,pin 56?
    I fixed all oor cells along with B3647, hopefully when it warms up a little and stops raining i can start tuning this vega. A 6.0 with a turbo should move it ok..
  8. #28
    I thought J2 is C2...
  9. #29
    Aug 2010
    If you look at the the PCM ... there is "J1 BLUE" cast into the metal body of the PCM, near the BLUE (C1 / J1 / X1) connector. The terms are used interchangeably.
  1. Is there any COS for e38 other than the ethanol COS ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: July 8th, 2012, 09:54 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. 7.4.2 Cos
    By Chevy366 in forum Custom Operating Systems
    Last Post: April 27th, 2007, 09:45 AM
