Need a file
Can anyone provide me with a file for a 2013 Camaro with a 102MM throttle body? My brother's just finished building a supercharged 416cid for his, but still has the stock throttle body. Problem, his tuner has files for cable driven 102MM throttle bodies but not for a DBW one. I mainly need the tables associated to the 102MM so he can get one on the car. It dynoed 816HP and 824TQ as it sits, but he should be getting quite a bit more out of it as it's a pretty aggressive build, including methanol injection and a small nitrous shot. I did a search but didn't find anything for a DBW 102MM.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
