Results 1 to 9 of 9
Thread: Transmission tuning licenses
    Apr 2007
    Default Transmission tuning licenses
    As I get licenses I get a transmission tuning license, however I have not seen where to tune a 6l80 / 90? There seem to be no settings in the software.
    Help?
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Aug 2016
    What car/truck are you working on? If you have a six speed auto, it should have a separate TCM and calibration. You'll need to read the tune for the trans, edit, then flash it separately from the engine.
    Sent from my Pixel 3 using Tapatalk
    Apr 2007
    2014 GMC Sierra, I was using 7.5 to tune, I see on 8 where it says "select trans controller". Going in!
    You sjould be able to read the TCM with V7.5.
    Apr 2007
    I will look around, but I didn't immediately see it.
    Aug 2016
    In V7.5, it's similar to reading an engine tune. When you connect, you'll get the little dialog box that asks you to choose what controller you're working with. I think the 2014 Sierra uses the E92 for the engine and the T87 for the transmission, so you'd choose T87 from the dropdown box, then read the calibration.
    Although, I opened up V7.5 to double check myself, and I didn't see some of the later transmission controllers there. Maybe it's only able to be read from V8? I might have missed it.
    Aug 2016
    Ahh, I think the T87 was for an 8 speed trans, T43 was still 6 speed if that's what you're working with.
    Jan 2021
    Quote Originally Posted by pinstripebob View Post
    My friend acquired this 2015 GMC Sierra with a 7.5 tune. We'll just wait for it to return from tire mounting and balancing before we can check the calibration. The previous owner mentioned they tried to check the transmission at T87.
    Aug 2016
    Sounds good! V8 is nice because you can click auto detect, then click the trans controller and read it. Tunes can be read and edited in either 7.5 or 8, they aren't locked to one version of EFILive.
  1. Transmission Tuning
    By twildman in forum Cummins 5.9L
    Last Post: May 11th, 2021, 09:36 AM
  2. LBZ transmission tuning
    By athoma94 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 17th, 2016, 07:43 AM
  3. Transmission tuning for economy
    By Extinct in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 16th, 2014, 05:25 PM
  4. Transmission Tuning
    By FUBAR in forum Cummins 5.9L
    Last Post: November 20th, 2012, 12:43 AM
  5. Transmission Tuning
    By Trapper in forum Cummins 5.9L
    Last Post: January 6th, 2012, 03:16 PM
