Results 1 to 4 of 4
Thread: Program a new ECM
    Apr 2010
    Default Program a new ECM
    I'm might be looking at replacing my ECM. I believe this is the part number #12633238. Truck is a 2012 Silverado with 5.3L afm. I would like to know if I can program it with efilive, or if I would still need to take it into a dealer. Does anyone know?
    I am having a mystery misfire issue p0307, where everything checks out good. I know the lifters have issues, but my rockers seem to be moving good while running, the cam lobes look good, and the lifters are free in the bores. I've checked or replaced everything else. So if I get this problem fixed, I'll want to disable the afm anyway, which I hope I can do with efilive.
    So can you avoid going to the dealer for ecm programming by using efilive?
    2006 K2500 CC LB LBZ Diesel
    Apr 2010
    I guess no one is using efilive to program a new ecm. I got a new ecm, flashed great, vin change seems to have worked. Won't start. CEL flashes. P0602 control module not programmed. Can't find any information past others posting the same question, and not getting an answer.
    Looks like I need to waste some money and have the dealer program it.
    I figured I'd try replacing the ecm rather than rebuild the engine when I can't find a fault with either. I know ecms are better at hiding their wierd faults.
    Dec 2016
    Hiya,
    I don't use EfiLive to program a NEW ecm, only used one's from same make,model,engine,trans. I use a MDI and GM SPS for that so all modules are written, including the slave modules. Neither EfiLive nor HpTuners program the slave modules(7,8). Then when all modules are written, you have to do a VATS relearn and crank/cam relearn.
    p.s. Are you sure it's p0307 and not p0300? Chances are you have a bad DOD lifter.
    You cannot use EFILive to program a brand new ECM, you must use SPS.
    To perform your DOD delete on the software side once you've removed the DOD lifters, you need to use EFILive as SPS will not do it.
  1. Anyone have a 4L80E program?
    By Telco in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 20th, 2013, 03:10 PM
  2. How to: Program injector flow data from GPM to ECM using EFILive V2
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 31st, 2012, 10:22 PM
  3. POCKET PC PROGRAM
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2005, 11:01 AM
