Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 2016 ram 2500 6.7 tune failed
    Senior Member Jim P's Avatar
    Nov 2019
    Straight up who ever you got your tuning from has no clue what he is talking about and you should get your money back from him. He is a retard, he has absolutely zero clue and has no business being in the tuning business. BBX is the configuration setup for your autocal to work on your truck, it has nothing to do with your tune file, it’s the configuration of your autocal. Get your money back from the guy and report him as an illegitimate person to get tuning from. Your autocal has to be configured to work on your truck before it can write the tune file to your truck.
    Nov 2019
    Your controller is the CME, it needs to be configured for that.
    May 2024
    OCDiesel is the one I got everything from I called today for a few questions that they would not answer requested a refund and got denied that refund I got fked hard on this. And now I have a brick sitting in front of my house.
    May 2024
    Jim p can I message you directly?
    Mar 2022
    Quote Originally Posted by Jamalfares View Post
    They used a AMDP tuning file I asked after talking to another tuner and he said they should be bbx I talked to the person that tried to tune the truck and he said they are not bbx files is there a way I can convert them to bbx files?
    No, you don't need a BBX file. You need to change BBX settings, as I outlined above. The tune file should be a CTZ file. You shouldn't need to do anything to it, if it's loaded on the Autocal.
    Nov 2019
    yes you can, if it's not working sending me an pm you can email me at marchosiasdiesel@gmail.com
    Nov 2019
    Never heard of OCDiesel
  9. #19
    May 2024
    Sent you a email.
  10. #20
    May 2024
    I will try this tonight when I am home thank you so much.
  1. 2017 ram 2500 6.7 68ref stock tune file
    By davidwhitaker in forum Cummins 6.7L
    Last Post: May 7th, 2024, 03:49 AM
  2. Dyno Tuning RAM 2500 68RFE
    By Truck-Tuning in forum Cummins 6.7L
    Last Post: March 28th, 2023, 09:59 PM
  3. Need 2016 Ram 2500 with AISIN transmission.
    By TurboTim in forum Diesel
    Last Post: August 21st, 2022, 06:47 AM
  4. 2020 brazilian ram 2500
    By romulo_sampaio in forum Cummins 6.7L
    Last Post: January 9th, 2020, 09:59 AM
  5. looking for base tune 2013 ram 2500 6.7 manual.
    By TZapoluch in forum Cummins 6.7L
    Last Post: September 16th, 2019, 11:46 AM
