Results 1 to 10 of 20
Thread: Actual AFR during cold idle
    Default Actual AFR during cold idle
    My VE table is dialed in (BEN's AT 1.00 in most places);
    during cold idle, my actual AFR is leaner than commanded, and then slowly converges as engine warms up;
    What tables are involved here, how do I explain this...?
    BEN map of the above log:
    BEN map after warmup:
    Junior Member carneb's Avatar
    My car does the same. I'dlike to know the answer too.
    Oct 2004
    All ours do it . In the custom OS3 & 5 I use the A0008 table to command richer mixture till partially warmed up (50*C). You may also be able to do the same by slowing the decay of general after-start enrichment.
    Bear in mind that your WBO2 sensor may also not be up to temp straight away and could account for the leanness also, I certainly see that.
    Andrew
    EFILive Crew
    Jan 2005
    This a long standing problem/mystery for SD.
    http://www.ls1tech.com/forums/showth...highlight=lean
    Don't think it was ever resolved either.
    Oct 2005
    Why worry? As mentioned mine is the same too. I noticed yours looked good Tordne in your logs. I might mess with A008 though as when cold it runs a little gutless.
    My logs show a sudden drop, not a gradual richening like that. Ill dig one out to show you.
    2014 VF SV LS3 Maloo.
    Jan 2005
    I believe you will find the IAC steps follow the same slope as the richening. My theory is the fueling doesn't account for the startup and startup friction airflow unless it's observed by the MAF (MAF guys don't seem to have this problem).
    Senior Member ArKay99's Avatar
    Apr 2004
    I had this problem at first too, I run an MAF. I found that if I turn off my A.I.R. to log cold AFR, That fixed my cold lean AFR issues. I was seeing 17:1 or more on my WB.
    Go:LPE 403, VaraRam, Haltech, PowerMax 100mm MAF, Tony Mamo ported FAST90/NW90, 160* stat, Kooks, TI's, DRM cutouts, Ripper, 4:10's, Tex OZ700, QA1's, Tony Mamo ported AFR 205's, 242/242 .610/.610 114LSA+2, Yella Terras, 42lb/hr Green tops, ASP UD pulley, 2 AMW catch cans
    Show: Euro tails & mrkrs, Z06 chromes/Pilots, 300Wx2 Bolt w/12" Sub,
    red calipers & black rear letters, Zaino.
    530 RWHP, 479 RWTQ
    Sep 2003
    Most of these guy have allready gotten rid of the AIR Pump
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Jan 2005
    Yes, my AIR pump has been on my bench for a while now.
    Spare PCM inputs
  1. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  2. Low (but stable) idle, bad response when cold ...
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: August 29th, 2006, 01:03 PM
  3. Cold start idle help
    Last Post: May 25th, 2006, 08:17 PM
  4. Which table controls (cold) Idle A/F ratio?
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2005, 08:03 AM
  5. OK, Getting frustrated... Damn Cold Idle!
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: November 28th, 2005, 02:13 PM
