If I get a "blank" 12200411 PCM, I can do a full flash to it, would that be correct...?
Um yes, if I get your question right. You have a "new" pcm and want to do a full flash. The only stipulation I can see is making sure the correct VIN shows up in the scanner after the full flash and inputing it via the scanner if need be.
www.efialchemy.com
www.greatamericancarwar.com
I hope so Joe, I'm waiting on one (a spare) from over your neck of the woods.
$90.....which is unbelievable!
Are you in Orange County Joe?
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Doc, I'm getting a spare and I'm wondering if a "blank" pcm contains flash loader code or if it's really "blank". Does entering the VIN in the tunetool's calibration tab write the VIN into the pcm...? What does the BCC field do...?
Howard, yes I'm in Orange County.![]()
I think someone on here asked this a little bit ago, and I heard that all PCM/ECM/TCMs have some sort of minimum bootloader code b/c otherwise how could the Tech II connect to it? I think it should work...
Try this forum....they're/we're all doing the 0411 swap. Some are using brand new 0411's out of the box.
http://www.pacificp.com/forum/viewfo...bc6666c85dd57f
http://www.pacificp.com/forum/viewtopic.php?t=3240
Joe, I'll be in LA from the 11th of June until the 26th of June....I was just curious!
EDIT: Are you an Aussie? I'll bring you a jar of Vegemite![]()
Howard
DUCT TAPE.
Howard,
Yes I am, I already have a jar of Vegemite in my fridge.
Where in LA are you going...?
Joe
HI Joe,
I practice Japanese Swordsmanship and my teacher lives in San Gabriel.
I'll be staying with him for 2 weeks.
I usually stay in a Hostel in West Hollywood. Been making the trip for....this will be the 8th time I think.
After that to visit a buddy in Virginia and then to AZ where another expat lives...he's also an ex funny car crew chief (Jim Walton Racing).
EDIT: what about a pollywaffle, or some Minties????
Howard
DUCT TAPE.
Yer... we're everywhere mate...
A Cherry Ripe would be nice...
We'll have to go to lunch or something.
Lol! OK....Lunch and a Cherry Ripe it is!
I'll bring you a few of the large ones!
Howard
DUCT TAPE.
