Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 202
Thread: options request : post your ideas
  1. #101
    Nov 2006
    How about being able to manually hide selected cells in a map.
    Right click menu or hot key.
    LC-1 WBO2
  2. #102
    Member 1BadAction's Avatar
    Mar 2009
    Quote Originally Posted by ssvolvo View Post
    How about defining/adjusting "hot mode" tables for T42,43?
    Also T43 missing tables for keeping Tap up/ Tap down "in gear"...NO overide.
    Thanks guys, I know this takes time!
    Cheers, John
    +1 With the climate down here, this is an addition that is needed badly.
    2013 1SS/1LE Blue Ray Metallic Camaro - DD
    1991 2500 Suburban - Roller cam'd high compression 454ci BBC tow monster
    1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
    1984 18' Contender Tunnel/2.4 Merc ModVP
  3. #103
    Just throwing this out there, any way to have the software scan for supported controllers when issuing a read (or write, that'd be even cooler) command and then read both the ECM and TCM out back to back? Maybe even have a dialog box pop up asking for save location and filename BEFORE the read so you are guaranteed a pair of untouched stock files. That would save some time and keep people from asking why they cant tune the trans. Of course keep the existing flash commands so if you have the trans setup perfectly and are tweaking the engine you dont have to flash both, just wondering if this could be added easily (or at all).
    But if not I can dream right?
  4. #104
    Nov 2006
    Can Milli-volts (mV) be added to the NBO2 PIDS? (imperial/metric)
    I know it can be done with a calc.pid making it somewhat frivolous,
    but why not.
    LC-1 WBO2
  5. #105
    but why not.
    You can add a custom unit for the HO2Sxx PIDs so that when you press Enter on FlashScan's keypad it changes between V and mV.
    To make mV one of the preset custom options for all PIDs with V units, you can add mV to the file:
    \ProgramData\EFILive\V8\EFILive.ini (Vista)
    or
    \Documents And Settings\All Users\Application Data\EFILive\V8\EFILive.ini (2K/XP)
    by adding an entry in the [Unit Conversions] section like this:
    0110=V mV 0 1000 0.000000 N
    Be aware that file (EFILive.ini) may get overwritten during a future update. Currently it is set to not be overwritten but that may change in future.
  6. #106
    Nov 2006
    Be aware that file (EFILive.ini) may get overwritten during a future update. Currently it is set to not be overwritten but that may change in future.l
    This is one reason I asked.
    It's not a big deal but in the scan tool GM.HOSxx is in volts only
    and in the tune tool O2 switch point {B4105} is in mV.
    LC-1 WBO2
  7. #107
    Good point, that got overlooked. They really should be the same units.
  8. #108
    Quote Originally Posted by Wolfie View Post
    Any chance for a "choose what directory the data files go into"?
    When installing the software, being able to choose my own directory would be nice,
    as I have the software on both my vehicle laptop and my "home" computer. Sure would make it easier keeping them in sync.
    Also I would like a new motorcycle for my birthday.
    While you can't select the data file folder name during the install, you can change it once the software is installed.
    Use the Scan Tool menu: Edit->Properties->Folders and highlight the "Logged Data" item. Then click the [Browse] button to select a different folder.
    You can also double-click on some items ("Logged Data" item included) to toggle the "remember last folder option".
  9. #109
    Default Another suggestion...
    Log filenames based on tune filenames...
    e.g.
    if tune filename is 12212156_0007.tun, then successive log filenames will automatically be:
    12212156_0007_0000.efi
    12212156_0007_0001.efi
    12212156_0007_0002.efi
    12212156_0007_0003.efi
    12212156_0007_0004.efi
  10. #110
    Nov 2006
    I use SyncToy v2.0 and an external HD to keep things sync'd and for back up.
    When I adjust or make a new file I'll Bluetooth the files between my 2 laptops or copy from the EHD, I'm too cheap to buy a USB transfer cable.
    What about my idea in post #1?
    LC-1 WBO2
  1. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 02:12 PM
  2. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 11:03 AM
  3. Any ideas up front
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 02:20 AM
