I installed version 7.5 and now my AFR map does not display AFR, it diplays the voltage output I think.
How do I get this straight?
Thanks,
Glenn
Thanks,
Glenn
Glenn,
Do you have FlashScan V1 or V2...?
If you have V2, read this:
Are you using analog AFR (connected via orange block) or serial AFR (connected via RJ12)...?
Either way, on the V2 LCD/keypad navigate to Options->Setup->Edit Settings, and then do this:
- if you're using analog AFR, set/enable the following parameters:
A/D PIDs
- if you're using serial AFR, set/enable the following parameters:
Ser PIDs
COM In
WO2 Type
WO2 fmt
WO2 Data
If your V2 LCD menu does not have those options, then you will have to update the bootblock/firmware also (i.e. install V8 and then carefully read and understand the upgrade/update document, do not proceed until you are clear on what is about to happen):
Thanks for the help, but I have V1
Glenn
Oh, with a V1 you should just select the AFR_LC11 and BEN_LC11 pids.
In your AFR and BEN maps, edit the map properties: on the Data tab set AFR_LC11 as the data.
You may have to validate pids first.
Joe,
Everything you asked is done. I transferred everything over from 7.3 and the data tabs in my map properties are correct.
When I am in F9, the data page in the scanner, I can see the AFR and it corresponds pretty well with when my LC1 gauge is putting out.
However, when I hit F11 to watch my maps, the AFR map is not showing AFR, but anywhere from 1.1 to 7.0 give or take.
The only thing different about my maps in 7.5 from 7.3 is that my BEN map is no longer in map A, it is in map C and my AFR is in map B. My cylinder air is in map A.
Would this be the problem?
I will go try it anyways.
Thanks,
glenn
map properties> data> parameter> AFR_LC11
LC-1 WBO2
I am stumped, I have done everything that you guys have suggested and I am still having a problem??
Glenn
Post up a log.
LC-1 WBO2
I just realized that my dash board is in Kilometers and C.
Maybe this is the problem. I am searching how to change it.
Glenn
