Results 1 to 6 of 6
Thread: flashscan V2 in dead poll mode....
    Aug 2008
    Default flashscan V2 in dead poll mode....
    i was trying to update my flashscan and left it pluged in and the power must have went out over night and now the screen will not iluminate anything but two orange flashing led's i tryed to check the status of the flashscan using the EFIlive flashscan V2 programer and all i get is...
    Flash scan V2 is not in "dead - Poll" mode.
    To enter Dead-Poll mod, hold down flashscans ctrl key when flash scan powers up. Dead poll mod is indicated by alternate flashing of the two orange LEDs.
    I held down the ctrl key when it was powering up and still got nothing.
    help greatly apreciated
    JAKE
    Jake,
    Welcome to the forum......I notified Tech Support.
    If you selected the Upgrade Boot Block option on your FlashScan, then you will need to use the V8 software EFILive_Explorer to program in the upgraded firmware which will finish off the upgrade process.
    The "EFIlive Firmware Programmer" software will not longer work with a FlashScan unit that has the upgraded boot block.
    The document: Start->All Programs->EFILive->V8->Documents->Upgrading Firmware explains the complete process.
    Hmm, what firmware/boot block did you try and program? Have you downloaded V8.1 and tried to flash it with EFILive Explorer?
    Edit: Got beat by Paul and joecar has more info...
    More info:
    showthread.php?t=9375 posts #9 and #10
    showthread.php?t=10014
    Read and understand everything before proceeding... also, see attached.
    Aug 2008
    thanks for your help guys my flash scan is back up and running now
  1. This is total BS - stuck in dead poll mode.
    By Mr. P. in forum FlashScan V2
    Last Post: September 9th, 2009, 09:35 AM
  2. stuck in dead poll mode
    By stacks04 in forum FlashScan V2 BB Logging
    Last Post: June 26th, 2008, 03:52 AM
  3. Dead Poll
    By sfcjones in forum Black Box Logging
    Last Post: March 26th, 2008, 01:10 PM
  4. V2 Stuck in dead poll
    By minytrker in forum FlashScan V2 BB Logging
    Last Post: November 28th, 2007, 10:25 AM
  5. PCM in Dead Poll State?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 6th, 2005, 11:19 AM
