Tried researching this issue and could not find anything.
My LM-1 meter reads rich but is smooth and consistent. The program sees afr from 12.5-16 or so in frame to frame. If I adjust the ve table to try to get LM_1 to stoich the program sees it as seriously lean. Idle is worse than steady throttle but still not acceptable for afr reading. I have dropped the channel count to 23 also but still the same issue and very noticable at idle especially. I have included a log file with 31 channnls for idle viewing as much as I could. Doesnt matter if 31 channels or 23 channels I get the same results at idle or on steady throttle.
I am sure the program is using a lot more info than the LM-1 but for a while I was thinking it is the wideband sensor but that doesnt make sense to me when the lm-1 is smooth and pretty sure that is correct.
I monitor thru the dashboard B and can see the lm1 afr is jumping like crazy. I was also assuming the timing could be the culprit but no matter what I do with the timing I cant get the programs lm-1 afr to smooth out Its tough to work the timing when the AFR isnt stable at all.
Car runs nice but I will not full throttle it till I figure this one out. I blip the throttle and very responsive but dont dare to hold it down. I know when the program says 18 afr there is no knock while the lm-1 meter reads according to commanded or even a little richer.
I am running in olsd and thought maybe I was in semi olsd but checked everything several times and could not find the problem. Seems afr is fighting to correct air and fuel every single frame though.
My iacdes_B and dynair are fairly close and idle is acceptable.
This is a F1-C procharger 90 mm throttle body using fast intake, mahle -32cc pistons, best callies crank and rods, 68cc dart pro1 heads, 75 lb injectors, (have an alcohol inj system on it and a 500 hp nitrous setup with the best controller but wont use it till this is right first). dual 255 walbros with kenny bell voltage multiplier.
I have adjusted the injector flow rate table according to rc engineering specs, I run .0157 for B4349 and is the only way I can get iacdes_B and dynair close. I am thinking maybe B4950 needs to be adjusted also but is stock at 84 right now. (I could not find any conclusive info on changing this so I wont touch it till I gather more info).
There is one other problem I found and doubt it is connected but when I check the speedo tire size settings every time it makes corections to H0102 and H0104 with transaxle checked. Running 1999 C5. Not sure what is going on there but it shows setting are saved then when I add scanning results and check speedo again it changes it every time.
I am running Version 7.5.5 build 72 and seems like because I am using V1 I cannot get any more updates beyond this unless I upgrade to v2 which I dont feel I need just to tune the same engine I have had for years. Since the updates are not downloadable from the website like they use to be that I can see. I am hoping I am wrong but doubt that would fix this issue I am having with the afr anyway.
I am posting a small log and have made some minor changes since then but you will see what I am talking about with the afr issue right off.
Thank you for your time in advance
