Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: LBZ DSP Beta1 Release
    Thumbs up LBZ DSP Beta1 Release
    Here it is, the first public beta release for the LBZ DSP upgrades.
    Before proceeding please consider this, you will need to update your software and V2 firmware to beta versions, if you are using EFILive as part of your business and feel uncomfortable about doing this then perhaps wait until the software and DSP updates are classified as stable releases (probably 2 - 3 weeks).
    The first step is you must update your software / firmware to the versions listed in the thread below.
    http://forum.efilive.com/showthread.php?t=12014
    Once you have updated your software and V2 firmware with the files in the thread above you can download the file attached to this post.
    You can download the pdf document detailing the process to upgrade your ECM to DSP2 or DSP5 from THIS location:
    This document should be saved in to the folder -
    \Program Files\EFILive\V7.5\Doc\Tutorials
    There is a zip archive attached to this post containing the necessary files for EFILive Tune to perform the DSP conversion. You must unzip these after installing the new software as it will overwrite the non DSP .calz files.
    These files need to be extracted in to the folder -
    \Program Files\EFILive\V7.5\Calibrations\E35
    The document pretty much spells out what needs to be done so I won't cover that again in this thread.
    If anybody strikes any problems with the DSP upgrade please don't do multiple post over multiple forums, it makes it very hard to track what is going on. You all know what Diesel forums we have a presence at, so post either on there or in this thread.
    Work is well under way for the LMM DSP, we expect that will be in public beta in 2 - 3 weeks, just before we leave for SEMA.
    Known issues with this Beta release:
    • None reported so far
    Enjoy!
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Thanks Ross! Great Job!
    07 El Bee Zee
    Little faster than stock...
    Mar 2007
    woohoo
    06 2500HD cc/sb 4X4
    LBZ Duramax Allison 6spd
    Mar 2009
    I cant get it to work
    Mar 2009
    Finally got it to work. Thanks for all the hard work
    Quote Originally Posted by tractor View Post
    If you can please pass on your experiences we can refine our guides if needs be.
    Lifetime Member McRat's Avatar
    Nov 2005
    Thanks Ross, Paul, et al.
    Question:
    When editing the DSP5 tune after initial install, will it have to be full-flash, or will a normal flash update the DSP segment?
    2005/2007 DHRA Western Drag Champion
    Bonneville A/DT & B/DT Land Speed Record Holder, 197mph best speed.
    Casper - 05 GMC 2500 Dmax LLY 10.59 @ 129, 916rwhp
    Big Blue - 04.5 GMC 3500SRW LLY 13.12 @ 104, 502rwhp sled puller
    Wendy - 06 GMC 2500 LBZ 12.50 @ 107.5 First LBZ into the 12's. 542rwhp.
    Blue Meanie - 02 Z06 11.40 @ 121 AFR H/C
    Dec 2005
    Normal calibration flash will update the DSP segments if changed.
    2011 LML 3500HD CC D/A 4x4
    2006 LBZ 3500 CC D/A 4x4 Sold
    2001 LB7 2500HD D/A 4x4 Sold
    The cal only flash will take a little longer now because we are writing the extra section where the DSP tables are stored. I think it only adds 15 seconds or so.
    As Biodiesel said, Cal flash for normal tuning, Full flash only to initially get the DSP OS in to the ECM.
    Nov 2005
    Great!
    I just got bit in the arse yesterday editing a LB7 DSP5 truck because I picked "cal-only", and it didn't do the DSP5 seg changes. I kept expecting the truck to behave differently after flashing. DOH!! So I was just curious.
    Waiting on switch or pins to play with it. Software loaded perfectly. Love the "automatic firmware update" feature.
  1. LMM DSP Beta1 Release
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 19th, 2009, 11:20 AM
  2. EFI not same release as V2?
    By RPM Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2008, 05:57 PM
  3. Pre release 7.5.1
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2007, 08:55 PM
  4. New release 533
    By eboggs_jkvl in forum FlashScan V2
    Last Post: July 12th, 2007, 02:34 AM
