Results 1 to 10 of 10
Thread: PCM Connection Problems
    Nov 2003
    Default PCM Connection Problems
    Just received FlasScan yesterday and the first time I hooked it up I could not connect to the PCM. Windows did see the USB connection but I could not connect. I am using XP Pro w/SP1. I tried a number of things, like reinstalled the software, removed Virus Software. So I deceided to try my EFILive Cable with version 6.0. I also tried my LS1Edit. Both could not connect. I have not used it for a couple of months. I tried another Notebook with the same problems. I am currently setting up a notebook with no virus software, no Window updates, nothing but windows, Adobe Reader and FlashScan. Has anyone had any problems with any Windows Updates that could cause a connection problem? If it is not the Notebook what on the car could cause it? The connector looks OK. Is there a fuse with this connector?
    Thanks.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Hey Bill,
    Given it has failed using the Flashscan adaptor, the old AutoTap adaptor and the LS1Edit adaptor sort of make me think it's something on the car perhaps?.
    When you plug in the flashscan adaptor to the car (without a PC hooked up), do the LED's cycle when first connected?, if yes then you have power at least, when the key is turned on does the OBD LED flicker?, if yes then you are getting data from the PCM, well, actually, you are getting data from something.
    If both those seem O.K then it points back to the PC.
    Give those few things a shot and let us know how you go.
    Nov 2003
    The FlashScan does go thru a light test when connected to the PC. I just tried plugging in the cable-box to the car without being connected to the PC. No lights. I even tried to push the start button.
    Bill
    Aug 2004
    did you verify 12 volt at the bottom right pin on the diagnostic port? if not check your cigarette fuse?
    Quote Originally Posted by BowlingSS
    Bill
    That's why I suggested plugging it in without the PC connected........you have no 12V at the DLC.
    Nov 2003
    It does not have power. Is that fuse under the side panel?
    Bill
    Nov 2003
    I checked the fuse and it was blown... I never use the lighter so I did know it was bad. Thanks guys.
    Bill
    Aug 2004
    Hi, Glad to help
    Aug 2004
    What are you doing REading these posts. GET out AND PLAY!
    Nov 2003
    Replaced the fuse and everything is working OK.
    Thanks.
    Bill
  1. Flash Scan box to usb cable connection problems
    By cmitchell17 in forum FlashScan V1
    Last Post: July 3rd, 2009, 04:17 AM
  2. No connection!
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2008, 12:33 PM
  3. Problems with V2 Connection
    By SV8346 in forum FlashScan V2
    Last Post: February 26th, 2008, 12:44 PM
  4. Connection problems
    By monaro308 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2008, 02:14 PM
  5. No connection
    By jannes_z-28 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2007, 08:57 AM
