EFILive V7.3.2 as of Apr 26, 2006.
This download completely replaces any existing EFILive software, it is a full installation.
V7.3.2 pre-release installation download (April 26, 2005):
http://www.efilive.com/download.aspx#v7_prerelease
Update (May 03, 2006):
http://68.178.219.18/software/EFILiveV732_update.zip (3Mb)
http://68.178.219.18/software/EFILiveV732_update.md5 (1Kb)
Instructions:The update fixes the following issues:
- Install the V7.3.2 pre-release software before attempting to apply this update.
- Unzip the EFILiveV732_update.zip file into the folder \Program Files\EFILive\V7. Overwrite all existing files with the same name.
PLEASE READ THIS FIRST
- Prevents the calibration D0400 from being displayed twice when viewing Duramax tune files.
- Dynamically applies limits to Duramax calibration C0806 to match the target ECM.
- Fixed potential full flash failure on selected LLY ECMs.
This is download is offered as pre-release software and may not be 100% bug free, please understand there may be some issues.
Check that the build numbers in the Help->About screens are:Please read the ' New Features.rtf ' file after installation to see the latest changes.
- Scan Tool: 411
- obdiiV7.dll: 535
- Tuning Tool: 454 (or 455 after the update is applied)
Of special note, the Allison TAP's can be viewed in the scantool under the menu option 'Calibration'.
When locking an Allison TCM you MUST have the tun file loaded that is in that TCM, read it first if you must.
You will be able to read/program the LL8 In-line 4.2L 6yl engine series (Trailblazer/Envoy), however, no calibration files will be released with this version.
Known issues:
Full Flashing a Duramax 2002/3/4 O.S back to a 2001 will result in a stuck oil life counter that will not reset.
Documentation has not been updated to reflect all the new features of the software.
Regards,
Ross & Paul
