I'll assume A0014 and I do believe it does. As far as I know, it basically takes place of the VE table when you are in the window you have setup.Originally Posted by Tordne
Yeah I did mean A0014 .
Cheers mate! Will be interesting to see how hard it will be to actually populate a map of TPS vs. RPM etc.
Andrew
EFILive Crew
how does the pcm know if you are spraying nitrous or just wot without nitrous?
By the nitrous input switch earthing the PCM inputOriginally Posted by minytrker
so basically like the same switching between two tunes with the duramax. just tie it into your arm switch and be set
A bit like that except it is the same tune just accessing a few extra offset tables to account for the spray. more akin to power/economy switch on the transOriginally Posted by minytrker
Ok so where is this elusive beast? I'd like to tickle its bottom.
2014 VF SV LS3 Maloo.
Just two to start with.
One for the Aussies to replace 12225074.
One for the 2002 F&Y bodies to replace 12212156
If you are already running a custom O.S based on one of those O.S's then all existing tunes are compatible.
Same process as the others, Full flash the O.S #5 tune in, then flash the cals only from the existing tune you are running, then read it out and save as your new O.S #5 file and adjust the new tables / parameters.
Setup suggestions.
A0003 - Set to disable for now until the tutorial is done (or you are feeling brave).
N20 monitor is done via the same input as the Valet mode, once it is grounded then the two compensation tables become active, although, there is two parameters to stop those two tables even if the N20 is on.
Good luck, let us all know how you go.
Download here -
http://efidownload.iqd.co.nz/softwar...5_OS_Final.zip
Ooooh a new challenge. Just when I was satisfied (finally) with my tune.
Let the games begin
Andrew
EFILive Crew
Cool, so what was it.. set A0003 to enable.. hehe..
