Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: Calculating Instantaneous Net Power
  1. #41
    Jun 2003
    M6/2k1/SS Vert
    In this run 4.226 second from 42-83 according to efi I went digging through the logs I have on my laptop here and cant find any 0-60 runs :(, i will dig through some to see what I can find.
    all the mods are on my site at http://www.2001camaross.com
    just goto the mods link.
  2. #42
    You have a very cool car (for all the right reasons)!
    8) 8)
  3. #43
    Jun 2003
    Just had to post a new best from today - VERY HAPPY
    391hp using my calc from above for accuracy: 3554 (SS Vert ) gm.fuelrem and dx at 12. Heck even dx at 6 it was at 385
    40-80 in 3.8 seconds SWEET!!!
    no 0-60 number because its an on ramp and I have to cross an intersection first.
  4. #44
    He he he... Power rules...!!!!
  5. #45
    Nov 2003
    [quote="dbaxter_ss"]Just had to post a new best from today - VERY HAPPY
    Can I get a copy of your PID you set up? Did you change the sae_generic file or place it in the cal_pids file?
    Thanks,
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
  6. #46
    Nov 2003
    Is this PID in 7.2.3? I see the old one but not the new one mentioned in this thread.
    Bill
  7. #47
    Derrick has the power formula dialled in pretty good. 8) 8) 8)
  8. #48
    Nov 2003
    Can you copy the cal_pid file you are using? I am not sure about the format.
    Thanks,
    Bill
  9. #49
    Jun 2003
    THese should work for you
    GTO
    CTS-V
    Z06
    and
    Vert SS
    Just replace the 185 in the calcs below with your own weight.
    I have the dx for 2, 6 and 12 then look at all three. the more pids you log the lower the dx. I usually look at all three. If you logging a bunch and do a 0-60, 2 will give the correct amount, but 12 will look like 100hp. Vice versa if you logging just a few things and do a 0-60, 2 will give 500hp when 12 shows 350.
    I can tell you that using the Z06 12 dx below, on the mustang dyno it pulled 322, on the street we pulled 327 so its pretty darn close, better ITS REAL, everything that affects TRUE HP is truely affecting your output. So anything slowing down VSS like FRICTION, Aerodynmic which NO DYNO can see will affect EFI since its logging the change in speed from each logged amount.
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units Low High Fmt Expression
    *CLC-00-979
    % -10.00 10.00 .2 "({SAE.SHRTFT1}+{SAE.SHRTFT2})/2"
    *CLC-00-980
    % -25.00 25.00 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2"
    *CLC-00-981
    AFR 0.00 15.00 .2 "14.63/{GM.EQIVRATIO}"
    *CLC-00-988
    AFR 0 20 .2 "({CALC.BEN_TE1}+{CALC.BEN_TE2})/2"
    *CLC-00-989
    hp 0.0 400.0 .0 "(((3554+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},6))/8226.63"
    *CLC-00-990
    hp 0.0 400.0 .0 "(((3554+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},12))/8226.63"
    *CLC-00-991
    hp 0.0 400.0 .0 "(((3775+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},6))/8226.63"
    *CLC-00-992
    hp 0.0 400.0 .0 "(((3775+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},12))/8226.63"
    *CLC-00-993
    cylair 0.0 4095.9 .0 "{CALC.CYLAIR} * 1000"
    *CLC-00-994
    hp 0.0 400.0 .0 "(((3554+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},2))/8226.63"
    *CLC-00-995
    hp 0.0 400.0 .0 "(((3800+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},12))/8226.63"
    *CLC-00-996
    hp 0.0 400.0 .0 "(((3800+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},2))/8226.63"
    *CLC-00-997
    hp 0.0 400.0 .0 "(((3800+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},6))/8226.63"
    *CLC-00-998
    hp 0.0 400.0 .0 "(((3117+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},2))/8226.63"
    *CLC-00-999
    hp 0.0 400.0 .0 "(((3117+({GM.FUELREM}*6.350)+185)*{SAE.VSS.mph})* dx({SAE.VSS.mph},12))/8226.63"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.LTAVG F601 CLC-00-980 % Fuel "Long Term Average"
    CALC.STAVG F611 CLC-00-979 % Fuel "Short Term Term Average"
    CALC.EQAFR F602 CLC-00-981 "AFR" External "AFR based on EQ 14.63:1"
    CALC.BEN_AUTHAVG F609 CLC-00-988 "AFR" External "Ben Auth Avg"
    CALC.SSHPTRUE6 F60A CLC-00-989 "kW,hp" Performance "SS TRUE HP 06"
    CALC.SSHPTRUE12 F60B CLC-00-990 "kW,hp" Performance "SS TRUE HP 12"
    CALC.GTOHPTRUE6 F60C CLC-00-991 "kW,hp" Performance "GTO TRUE HP 06"
    CALC.GTOHPTRUE12 F60D CLC-00-992 "kW,hp" Performance "GTO TRUE HP 12"
    CALC.MGCYLAIR F60F CLC-00-993 "cylair" Air "Millgrams Air mass per cylinder"
    CALC.SSHPTRUE1 F610 CLC-00-994 "kW,hp" Performance "SS TRUE HP 1xz"
    CALC.ctsv12 F611 CLC-00-995 "kW,hp" Performance "ctsv 12 hp"
    CALC.ctsv2 F612 CLC-00-996 "kW,hp" Performance "ctsv 2 hp"
    CALC.ctsv6 F613 CLC-00-997 "kW,hp" Performance "ctsv 6 hp"
    CALC.z06-2 F614 CLC-00-998 "kW,hp" Performance "z06 2 hp"
    CALC.z-6-12 F615 CLC-00-999 "kW,hp" Performance "z06 12 hp"
  10. #50
    Nov 2003
    Thanks for the info. I will give it a try. After a big meal I am also about 185...
    What are these for:
    Bill
  1. Calculating Injector Flow rate
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2012, 04:22 PM
  2. Calculating IFR slope with no vacuum reference?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2008, 03:59 AM
  3. Calculating Injector flow rate
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2007, 09:51 AM
  4. Replies: 6
    Last Post: September 25th, 2006, 07:01 AM
  5. Replies: 0
    Last Post: February 6th, 2006, 10:12 AM
