EFILive Forum
Go Back   EFILive Forum > Tuning > General (Petrol, Gas, Ethanol)
Reply
Thread Tools Display Modes
Old August 26th, 2006   #1
S10Wildside
Default Problems with CKP relearn on 2001 12200411 PCM
I converted a TPI engine to use the 12200411 PCM with a modified Express Van calibration.
The engine started right up and threw the following (expected) codes:
I was unable to successfully perform the crank relearn procedure. I initially had a transmission code P1810 that was preventing the relearn procedure, but after disabling that code, I still can't perform the relearn. I can press the relearn button and see the countdown, but when I rev the engine it'll go beyond 5,000rpm and never cut out the injectors. I've disabled all codes that EFILive is saying will prevent the CKP relearn procedure. I'm stumped. Any suggestions?
S10Wildside is offline   Reply With Quote
Old August 27th, 2006   #2
Dirk Diggler
Send a message via AIM to Dirk Diggler Send a message via MSN to Dirk Diggler
Does the car know its in park?
__________________
Larry - HumpinSS
Dirk Diggler is offline   Reply With Quote
Old August 29th, 2006   #3
ChipsByAl
ChipsByAl's Avatar
Or does the PCM know the position of the brake pedal?
Al
PS. if the donor file is a manual (not in this case) make sure the PCM knows the position of the clutch pedal.
__________________
ChipsByAl is offline   Reply With Quote
Old August 29th, 2006   #4
ChipsByAl
ChipsByAl's Avatar
Kewl project in either case. Are you using the 4L60-E, 4L80-E or another transmission?
AL
__________________
Old August 30th, 2006   #5
350SS
If he's running a 700R4 trans, does he just need to ground the park/neutral wire?
__________________
98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
72 Chevelle LQ9/4L80E/GT42 conversion in the works
http://www.ls1tech.com/forums/showthread.php?t=449129
350SS is offline   Reply With Quote
Old August 30th, 2006   #6
ChipsByAl
ChipsByAl's Avatar
Grounding the P/N wire will allow CKP learn to take place. If he uses a switch then he can take advantage of the idle tables as well. You can use a switch that grounds for the starter neutral safety "relay" and then it can double as a P/N switch to the PCM.
AL
__________________
Old August 30th, 2006   #7
S10Wildside
Quote:
I tried to spoof park and still no luck. I even tried chaning to a manual transmission. I couldn't see how to do this with EFILive, so I modified the PCM with TunerCat OBDII to change the tranny from an auto to manual. Still no good.
Old August 30th, 2006   #8
S10Wildside
Quote:
Al
The PCM does not know the position of the brake pedal. I suppose that would have to do with the TCC clutch power wire? If I recall, that's the only signal from the brake switch.
Old August 30th, 2006   #9
S10Wildside
I'll have a chance to look at this this weekend. I'm still unclear on the difference between the gear selector switch used in the Express van and the lack of that switch in the f-body. Don't know how that affects the PCM. The gear select switch has four wires from the PCM and the f-body only has two (pins 32 and 34 on the blue PCM connector). Even the colors changed. I expected to ground the orange/black wire to indicate park/neutral, but when I built the harness using the Express schematics, that wire is white and goes to "Transmission Range Switch P" (pin 34 on the blue PCM connector).
As far as the brake signal is concerned I see one input to the PCM, the purple TCC wire. That wire receives 12v when the pedal is not depressed and is open when the pedal is depressed. I have that wire open on the test stand. So I'm not convinced that the brake has to be depressed to perform the CKP relearn. It may be a safety precaution.
So that leaves me stumped again. Thanks for the ideas to this point. Any others are welcome!
Here's a video of the engine running on the test stand (still without the relearn).
http://www.eficonnection.com/12200411/12200411.mpg
Old August 30th, 2006   #10
ChipsByAl
ChipsByAl's Avatar
To perform the crank variation learn procedure with the Tech2, the brake pedal needs to be pressed. It may need to see the change as well, but I am not sure. I haven't used EFI live to do the learn yet so I can't comment on that. In either case I would try to simulate the switch. Disabling the brake switch or P/N codes doesn't change the PCM's "mind."
As far as the PRNDL switch wiring not being on the F-car, I wouldn't concern myself about that. The Camaro does not have the display in the cluster, it is on the shifter and moves with the lever only. The function of this switch could be added to EFI_Live to be enabled or disabled.
AL
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Wtb 12200411 Pcm ArcticWhtZ For Sale 7 September 30th, 2007 03:38 PM
Can't get PCM to do CASE relearn on new motor red12secz28 Gen III V8 Specific 3 May 7th, 2007 10:02 AM
Swapping 12200411 PCM into 98 Chevy Truck 350SS General (Petrol, Gas, Ethanol) 28 April 8th, 2007 10:53 AM
CKP Relearn 91LS1S10 General (Petrol, Gas, Ethanol) 32 November 29th, 2006 07:21 AM
PCM Connection Problems BowlingSS General (Petrol, Gas, Ethanol) 9 February 24th, 2005 05:09 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
