Results 1 to 6 of 6
Thread: Using EFILive scanner with an ODBII LT1
    Nov 2006
    Default Using EFILive scanner with an ODBII LT1
    I've purchased EFILIVE and have been sucessfully using it with my '97 LT1 for a few months. Most all of the important GM extended parameters I need are recognized, except one: Knock Retard.
    I did some research and found docs that indicate the GM PID for "retard due to knock" on an LT1 is $125D. I tried making a custom pid using this, and EFILive actually did validate the PID and start logging it. However, the pid only ever came up as zero (ive verified i have knock retard using my autotap setup).
    I'm not sure what else i could try -- its just seems strange that this one PID would not work when most all of the others do. Its also weird that the custom pid is recognized, but comes up with no real data. Are there other scanning modes i could try?
    Kyle,
    Welcome to the forum.
    I pm'd Paul, he'll get back to you soon (after SEMA...).
    Cheers
    Joe
    I've added it to gm_enhanced.prn which is attached.
    Exit out of both the scan and tune software.
    Download the attached zip file, unzip it into:
    \Program Files\EFILive\V7\Configuration, overwriting the existing gm_enhanced.prn file.
    Test it and let me know if it is ok and I'll include it in the next release.
    Nov 2006
    Got the file, I'll try it tonight.
    Nov 2006
    The new prn worked great, I was able to select and log the LT1 knock retard and all the data values were consistant with what i saw from autotap.
    Thanks alot!!
    Jul 2003
    I cant find this!!!!!???? Which PID needs to be logged>???
  1. does efilive do general odbii scanning for non gm?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2010, 03:53 PM
  2. AVG virus scanner
    By joecar in forum Lounge
    Last Post: July 29th, 2009, 08:59 PM
  3. Need longer ODBII cable for V2
    By minytrker in forum FlashScan V2
    Last Post: March 20th, 2009, 03:34 PM
  4. Scanner help
    By wickedred in forum General (Petrol, Gas, Ethanol)
    Last Post: June 22nd, 2007, 11:10 AM
  5. upgrading from V6 to V7 - Scanner only -
    By Blackbird in forum General (Petrol, Gas, Ethanol)
    Last Post: March 24th, 2005, 10:02 AM
